Okay here is my main.c. For line 144 check the void vApplicationMallocFailedHook(void) function
/* Standard includes. */
#include <stdio.h>
#include <stdlib.h>
#include <conio.h>
/* Visual studio intrinsics used so the __debugbreak() function is available
should an assert get hit. */
#include <intrin.h>
/* FreeRTOS kernel includes. */
#include "FreeRTOS.h"
#include "task.h"
/* This project provides two demo applications. A simple blinky style demo
application, and a more comprehensive test and demo application. The
mainCREATE_SIMPLE_BLINKY_DEMO_ONLY setting is used to select between the two.
If mainCREATE_SIMPLE_BLINKY_DEMO_ONLY is 1 then the blinky demo will be built.
The blinky demo is implemented and described in main_blinky.c.
If mainCREATE_SIMPLE_BLINKY_DEMO_ONLY is not 1 then the comprehensive test and
demo application will be built. The comprehensive test and demo application is
implemented and described in main_full.c. */
#define mainCREATE_SIMPLE_BLINKY_DEMO_ONLY 0
/* This demo uses heap_5.c, and these constants define the sizes of the regions
that make up the total heap. heap_5 is only used for test and example purposes
as this demo could easily create one large heap region instead of multiple
smaller heap regions - in which case heap_4.c would be the more appropriate
choice. See http://www.freertos.org/a00111.html for an explanation. */
#define mainREGION_1_SIZE 8201
#define mainREGION_2_SIZE 29905
#define mainREGION_3_SIZE 7807
* main_blinky() is used when mainCREATE_SIMPLE_BLINKY_DEMO_ONLY is set to 1.
* main_full() is used when mainCREATE_SIMPLE_BLINKY_DEMO_ONLY is set to 0.
extern void main_blinky(void);
extern void main_full(void);
* Only the comprehensive demo uses application hook (callback) functions. See
* http://www.freertos.org/a00016.html for more information.
void vFullDemoTickHookFunction(void);
void vFullDemoIdleFunction(void);
* This demo uses heap_5.c, so start by defining some heap regions. It is not
* necessary for this demo to use heap_5, as it could define one large heap
* region. Heap_5 is only used for test and example purposes. See
* http://www.freertos.org/a00111.html for an explanation.
static void prvInitialiseHeap(void);
* Prototypes for the standard FreeRTOS application hook (callback) functions
* implemented within this file. See http://www.freertos.org/a00016.html .
void vApplicationMallocFailedHook(void);
void vApplicationIdleHook(void);
void vApplicationStackOverflowHook(TaskHandle_t pxTask, char* pcTaskName);
void vApplicationTickHook(void);
void vApplicationGetIdleTaskMemory(StaticTask_t** ppxIdleTaskTCBBuffer, StackType_t** ppxIdleTaskStackBuffer, uint32_t* pulIdleTaskStackSize);
void vApplicationGetTimerTaskMemory(StaticTask_t** ppxTimerTaskTCBBuffer, StackType_t** ppxTimerTaskStackBuffer, uint32_t* pulTimerTaskStackSize);
* Writes trace data to a disk file when the trace recording is stopped.
* This function will simply overwrite any trace files that already exist.
static void prvSaveTraceFile(void);
/* When configSUPPORT_STATIC_ALLOCATION is set to 1 the application writer can
use a callback function to optionally provide the memory required by the idle
and timer tasks. This is the stack that will be used by the timer task. It is
declared here, as a global, so it can be checked by a test that is implemented
in a different file. */
StackType_t uxTimerTaskStack[configTIMER_TASK_STACK_DEPTH];
/* Notes if the trace is running or not. */
static BaseType_t xTraceRunning = pdTRUE;
TaskHandle_t myTaskHandle = NULL;
int main(void) {
/* This demo uses heap_5.c, so start by defining some heap regions. heap_5
is only used for test and example reasons. Heap_4 is more appropriate. See
prvInitialiseHeap();
/* Initialise the trace recorder. Use of the trace recorder is optional.
See http://www.FreeRTOS.org/trace for more information. */
vTraceEnable(TRC_START);
/* The mainCREATE_SIMPLE_BLINKY_DEMO_ONLY setting is described at the top
of this file. */
#if ( mainCREATE_SIMPLE_BLINKY_DEMO_ONLY == 1 )
main_blinky();
#else
/* Start the trace recording - the recording is written to a file if
configASSERT() is called. */
printf("\r\nTrace started.\r\nThe trace will be dumped to disk if a call to configASSERT() fails.\r\n");
printf("Uncomment the call to kbhit() in this file to also dump trace with a key press.\r\n");
uiTraceStart();
main_full();
return 0;
/* vApplicationMallocFailedHook() will only be called if
configUSE_MALLOC_FAILED_HOOK is set to 1 in FreeRTOSConfig.h. It is a hook
function that will get called if a call to pvPortMalloc() fails.
pvPortMalloc() is called internally by the kernel whenever a task, queue,
timer or semaphore is created. It is also called by various parts of the
demo application. If heap_1.c, heap_2.c or heap_4.c is being used, then the
size of the heap available to pvPortMalloc() is defined by
configTOTAL_HEAP_SIZE in FreeRTOSConfig.h, and the xPortGetFreeHeapSize()
API function can be used to query the size of free heap space that remains
(although it does not provide information on how the remaining heap might be
fragmented). See http://www.freertos.org/a00111.html for more
information. */
vAssertCalled(__LINE__, __FILE__); **>>>>>>>> LINE 144 !!!!**
/* vApplicationIdleHook() will only be called if configUSE_IDLE_HOOK is set
to 1 in FreeRTOSConfig.h. It will be called on each iteration of the idle
task. It is essential that code added to this hook function never attempts
to block in any way (for example, call xQueueReceive() with a block time
specified, or call vTaskDelay()). If application tasks make use of the
vTaskDelete() API function to delete themselves then it is also important
that vApplicationIdleHook() is permitted to return to its calling function,
because it is the responsibility of the idle task to clean up memory
allocated by the kernel to any task that has since deleted itself. */
/* Uncomment the following code to allow the trace to be stopped with any
key press. The code is commented out by default as the kbhit() function
interferes with the run time behaviour. */
if( _kbhit() != pdFALSE )
if( xTraceRunning == pdTRUE )
vTraceStop();
prvSaveTraceFile();
xTraceRunning = pdFALSE;
#if ( mainCREATE_SIMPLE_BLINKY_DEMO_ONLY != 1 )
/* Call the idle task processing used by the full demo. The simple
blinky demo does not use the idle task hook. */
vFullDemoIdleFunction();
(void)pcTaskName;
(void)pxTask;
/* Run time stack overflow checking is performed if
configCHECK_FOR_STACK_OVERFLOW is defined to 1 or 2. This hook
function is called if a stack overflow is detected. This function is
provided as an example only as stack overflow checking does not function
when running the FreeRTOS Windows port. */
/* This function will be called by each tick interrupt if
configUSE_TICK_HOOK is set to 1 in FreeRTOSConfig.h. User code can be
added here, but the tick hook is called from an interrupt context, so
code must not attempt to block, and only the interrupt safe FreeRTOS API
functions can be used (those that end in FromISR()). */
vFullDemoTickHookFunction();
#endif /* mainCREATE_SIMPLE_BLINKY_DEMO_ONLY */
void vApplicationDaemonTaskStartupHook(void)
/* This function will be called once only, when the daemon task starts to
execute (sometimes called the timer task). This is useful if the
application includes initialisation code that would benefit from executing
after the scheduler has been started. */
void vAssertCalled(unsigned long ulLine, const char* const pcFileName)
static BaseType_t xPrinted = pdFALSE;
volatile uint32_t ulSetToNonZeroInDebuggerToContinue = 0;
/* Called if an assertion passed to configASSERT() fails. See
http://www.freertos.org/a00110.html#configASSERT for more information. */
/* Parameters are not used. */
(void)ulLine;
(void)pcFileName;
printf("ASSERT! Line %ld, file %s, GetLastError() %ld\r\n", ulLine, pcFileName, GetLastError());
taskENTER_CRITICAL();
/* Stop the trace recording. */
if (xPrinted == pdFALSE)
xPrinted = pdTRUE;
if (xTraceRunning == pdTRUE)
vTraceStop();
prvSaveTraceFile();
/* Cause debugger break point if being debugged. */
// __debugbreak();
/* You can step out of this function to debug the assertion by using
the debugger to set ulSetToNonZeroInDebuggerToContinue to a non-zero
value. */
while (ulSetToNonZeroInDebuggerToContinue == 0)
__asm { NOP };
__asm { NOP };
taskEXIT_CRITICAL();
FILE* pxOutputFile;
fopen_s(&pxOutputFile, "Trace.dump", "wb");
if (pxOutputFile != NULL)
fwrite(RecorderDataPtr, sizeof(RecorderDataType), 1, pxOutputFile);
fclose(pxOutputFile);
printf("\r\nTrace output saved to Trace.dump\r\n");
printf("\r\nFailed to create trace dump file\r\n");
/* The Windows demo could create one large heap region, in which case it would
be appropriate to use heap_4. However, purely for demonstration purposes,
heap_5 is used instead, so start by defining some heap regions. No
initialisation is required when any other heap implementation is used. See
http://www.freertos.org/a00111.html for more information.
The xHeapRegions structure requires the regions to be defined in start address
order, so this just creates one big array, then populates the structure with
offsets into the array - with gaps in between and messy alignment just for test
purposes. */
static uint8_t ucHeap[configTOTAL_HEAP_SIZE];
volatile uint32_t ulAdditionalOffset = 19; /* Just to prevent 'condition is always true' warnings in configASSERT(). */
const HeapRegion_t xHeapRegions[] =
/* Start address with dummy offsets Size */
{ ucHeap + 1, mainREGION_1_SIZE },
{ ucHeap + 15 + mainREGION_1_SIZE, mainREGION_2_SIZE },
{ ucHeap + 19 + mainREGION_1_SIZE + mainREGION_2_SIZE, mainREGION_3_SIZE },
{ NULL, 0 }
/* Sanity check that the sizes and offsets defined actually fit into the
array. */
configASSERT((ulAdditionalOffset + mainREGION_1_SIZE + mainREGION_2_SIZE + mainREGION_3_SIZE) < configTOTAL_HEAP_SIZE);
/* Prevent compiler warnings when configASSERT() is not defined. */
(void)ulAdditionalOffset;
vPortDefineHeapRegions(xHeapRegions);
/* configUSE_STATIC_ALLOCATION is set to 1, so the application must provide an
implementation of vApplicationGetIdleTaskMemory() to provide the memory that is
used by the Idle task. */
/* If the buffers to be provided to the Idle task are declared inside this
function then they must be declared static - otherwise they will be allocated on
the stack and so not exists after this function exits. */
static StaticTask_t xIdleTaskTCB;
static StackType_t uxIdleTaskStack[configMINIMAL_STACK_SIZE];
/* Pass out a pointer to the StaticTask_t structure in which the Idle task's
state will be stored. */
*ppxIdleTaskTCBBuffer = &xIdleTaskTCB;
/* Pass out the array that will be used as the Idle task's stack. */
*ppxIdleTaskStackBuffer = uxIdleTaskStack;
/* Pass out the size of the array pointed to by *ppxIdleTaskStackBuffer.
Note that, as the array is necessarily of type StackType_t,
configMINIMAL_STACK_SIZE is specified in words, not bytes. */
*pulIdleTaskStackSize = configMINIMAL_STACK_SIZE;
/* configUSE_STATIC_ALLOCATION and configUSE_TIMERS are both set to 1, so the
application must provide an implementation of vApplicationGetTimerTaskMemory()
to provide the memory that is used by the Timer service task. */
/* If the buffers to be provided to the Timer task are declared inside this
static StaticTask_t xTimerTaskTCB;
/* Pass out a pointer to the StaticTask_t structure in which the Timer
task's state will be stored. */
*ppxTimerTaskTCBBuffer = &xTimerTaskTCB;
/* Pass out the array that will be used as the Timer task's stack. */
*ppxTimerTaskStackBuffer = uxTimerTaskStack;
/* Pass out the size of the array pointed to by *ppxTimerTaskStackBuffer.
*pulTimerTaskStackSize = configTIMER_TASK_STACK_DEPTH;
