Why are more embedded systems moving from bare-metal to RTOS/OS (Linux, FreeRTOS)
Hi everyone,
I’ve observed a growing trend in modern embedded systems development: many applications are increasingly built using an RTOS (e.g., FreeRTOS) or even a full-fledged OS like Linux, rather than relying on traditional bare-metal programming—even in cases where bare-metal could technically meet the requirements.
Is this shift primarily driven by long-term maintenance benefits? Or are there other key factors?
The use of a simple OS allows partitioning the program into seperate operations, that make the design more scalable. The “Bare-metal” design method helps to optimize resource usage at the cost of needing to think of the full system as a monlith. Since processor resources are growing, the need to be ultra-efficient in your resource usage is less important, and a much more important aspect becomes the cost to create the program.
Thus, except in the cases of very mass markets with very cost sensitive markets, (which shifts the design to wanting bare minimal hardware, and can pay more for software development to do that, since the software cost gets divided over more units) it is cost effective to use a more structured designed.
My take on Linux vs FreeRTOS is it’s more about available drivers and the ability to use gpl code without license issues. However, there are tradeoffs, if you’ve ever used yocto you’ll understand. IMO you move it from an individual developer level to a team.
Software is a living entity, even the embedded software.
There often comes a point where bare-metal software can no longer keep up with the growing complexity of an application. It doesn’t scale at the same rate, and over time, the project can devolve into an unmanageable mess.
In the early days, microcontrollers were heavily constrained in terms of resources—limited FLASH, RAM, clock speeds, and so on. But that’s no longer the case. Today, for just a couple of dollars, you can get a microcontroller with 512 KB of FLASH and 32 KB of RAM, running at 64 MHz or more. Pretty amazing, right? And if you spend a little more, you can get a powerhouse of a microcontroller.
Back then, these limitations made it difficult to integrate an operating system—it simply wouldn’t fit in memory. But with modern MCUs offering plenty of headroom, we as developers can focus more on application design rather than obsessing over every byte or CPU cycle. Twenty years ago, that kind of optimization was the norm. I remember it well: you’d write a procedure in assembly and then count the bytes and cycles it used. Just look at the old COP8 datasheets for a reminder!
Today, operating systems with small footprints—like FreeRTOS—can easily fit on most modern microcontrollers without consuming excessive resources. Linux and RTLinux, on the other hand, are suited for a different class of embedded systems. Linux is a full-featured OS and is overkill unless your application truly requires its capabilities.
Why using a RTOS is a good idea?
An RTOS like FreeRTOS provides a structured framework for your application: tasks, inter-task communication, synchronization mechanisms, and more. This structure allows applications to scale more easily than traditional bare-metal designs. Of course, using any framework requires careful planning before writing code—but that’s actually a benefit, not a drawback.
Even better, combining FreeRTOS with C++ unlocks additional advantages. While most RTOSes are written in C and typically used that way, C++ brings higher-level abstractions such as templates and interfaces, which can make your code more expressive, modular, and maintainable.
In short RTOSs, and in particularly FreeRTOS, promote better structure, scalability, and maintainability for new projects where long-term growth, reliability, and clarity are essential even when one thinks only in the first version of the application (and that it will be the only :roll_eyes:).
And those powerhouses are much more complex than the old controllers. For example to actually save power it is no longer enough to reduce the clock speed, but power gating has to be taken into account. A timer no longer has two registers but 16, etc.
It is much easier to solve such things once and then reuse, ergo have an OS based setup, instead of trying to think of all those things all the time.
Also, If you haven’t done that already, @RTOS1 I would advise you to look into the actual code(size) of FreeRTOS in particular. A lot of the concepts solved there will be necessary for a “can be solved bare metal” application anyway, while I wouldn’t bet on that “bare metal solution” to actually be much smaller.
It is a completely different category from what Linux, or even Zephyr, does.
Many true “bare metal” applications are implemented as super-loops with interrupt level code providing the only preemptive event handling. This is fine for simple things, but a lot of embedded applications benefit from priority based preemptive multi-threading at user level, allowing each thread to maintain only its own context; the super-loop approach provides much less modularity and state independence. For example, the ability to block on multiple I/O completions, parsing characters as they arrive and then taking some action when it’s done, while other threads continue to execute rather than polling from the super-loop and conditionally parsing the buffer built up over many loops makes the code easier to write, read, and maintain.
To amplify what others have already said, an RTOS provides a consistent framework for implementing multiple threads/tasks, synchronization, timer services. FreeRTOS is fairly close to bare metal, and in my old-school taxonomical view it is less an OS than an embedded executive.
I’ve implemented my own multi-threading executives that are smaller and less featureful than FreeRTOS in the past, but none of those have been portable (nor were they intended to be). I spent almost as much time debugging the context switching as I did writing the application code.
