Hello;
I am needing portmacro.h But there so many portmacro.h in freertos Which file shoul I use?
On the other hand I tried this portmacro.h :Source\portable\owatcom\16bitdos\pc\portmacro.h
But now I have this error:
Description Resource Path Location Type
'nop' undeclared (first use in this function) portmacro.h /osiloskop/src line 141 C/C++ Problem
expected ';' before '}' token portmacro.h /osiloskop/src line 141 C/C++ Problem
expected '(' before '{' token portmacro.h /osiloskop/src line 141 C/C++ Problem
That depends on the compiler you are using. The easiest thing to do
though is use the pre-configured project we provide as that will already
be using the correct portmacro.h file. Alternatively get the Xilinx SDK
to generate a FreeRTOS project for you, as that too will use the correct
portmacro.h file.
The directory structure is described on this link: http://www.freertos.org/a00017.html - from which you will see that you
have included a portmacro.h file intended for use with the Open Watcom
x86 compiler.
If you are using GCC then you will need the file from
FreeRTOS/Source/portable/GCC/ARM_CA9 (Cortex-A9).
'XPAR_ENCODER_BTN_GPIO_DEVICE_ID' undeclared (first use in this function) mem_control.c /osiloskop/src line 199 C/C++ Problem
'XPAR_GPIO_TRIGGER_CONTROL_DEVICE_ID' undeclared (first use in this function) mem_control.c /osiloskop/src line 56 C/C++ Problem
'XPAR_GPIO_TRIGGER_SETTINGS_DEVICE_ID' undeclared (first use in this function) mem_control.c /osiloskop/src line 73 C/C++ Problem
'XPAR_SCREEN_BUFFER_GPIO_DEVICE_ID' undeclared (first use in this function) mem_control.c /osiloskop/src line 88 C/C++ Problem
I’m afraid we cannot support other peoples code, only code we provide
ourselves. We can support code from the FreeRTOS download, the FreeRTOS
Labs download (if you want Ethernet and SD card support), or generated
by the Xilinx SDK. Instructions for using our code can be located on
the FreeRTOS.org website.
