jqpublick wrote on Thursday, July 27, 2006:
In April there was a lot of discussion regarding work on a uip GCC port for the sam7x. What happened to this?
Thanks
- Joe
Thanks
- Joe
rtel wrote on Thursday, July 27, 2006:
In short, not sure. The longer answer is:
There is a GCC port for the SAM7X that uses lwIP. It would not be a difficult job to take out the lwIP source and add the uIP source, as you can use the uIP/IAR source code as a base to see which files you need to include.
I also have some other GCC SAM7X ports that don’t have uIP in them but are more optimised for code size. These were sent to me from a third party so cannot support them directly (although obviously I will help where I can). If you want a copy then let me know.
Can you send me a link to the April thread so I know which you are referring to and can refresh my memory of what was said and/or done.
jqpublick wrote on Friday, July 28, 2006:
Here are the two threads from April:
http://sourceforge.net/forum/message.php?msg_id=3700971
http://sourceforge.net/forum/message.php?msg_id=3703497
- Joe
