What's the CORRECT way to send a Queue message from another module?
groger57 wrote on Friday, May 01, 2015:
Instead of asking what’s WRONG with my code, can someone please point me to an example, or provide an example, of the correct way to use xQueueSend from a module other than where the queue handle and function handler are defined?
I’m using FreeeRTOS 8.2.0, in IAR EWARM 7.3, on an STM32F4 controller. I am unable to find an example on the entire web that shows this, and it just happens to be giving me a big headache right now.
Thank you…
rtel wrote on Friday, May 01, 2015:
It shouldn’t make any difference which module the queue handle is defined in. A queue handle is just a variable, so it can be declared in one C file, and then extern’ed in another C file, just like any other variable.
File1.c
/* Declared globally. */
QueueHandle_t xQueue = NULL;
int main( void )
   xQueue = xQueueCreate( 5, sizeof( uint32_t ) );
   /* Start tasks. */
   /* Start scheduler. */
void vTask1InFile1( void *pvParameters )
uint32_t DataToSend = 0, DataToReceive;
const TickType_t xBlockTime = pdMS_TO_TICKS( 200 );
    for( ;; )
        xQueueSend( xQueue, &DataToSend, xBlockTime );
        xQueueReceive( xQueue, &DataToReceive, xBlockTime );
File2.c
void vTask2InFile2( void *pvParameters )
/* Here the queue handle is extern. */
extern QueueHandle_t xQueue;
    for( ;; )
