Warnings about pack_struct_end.h and IAR
I’ve a project in IAR which use freeRTOS+TCP. When I compile there were a lot of warnings like this:
FreeRTOS_IP_Private.h",229  Warning[Pe1644]:
          definition at end of file not followed by a semicolon or a declarator
I have incuded pack_struct_start.h and pack_struct_end.h in my project and they are used but it seems IAR compiler doesn’t like the pack_struct_end.h which only have a ;
The problem is solve if I include a semicolon after the } in the end of structs but I don’t understand why the pack_struct_end.h file is not working.
Are you including these files explicitly? Can you share complete build log?
This is the code (an example, the same warning appears any time pack_struct_end.h is included) that raise the warning:
#include "pack_struct_start.h"
    struct xUDP_PACKET
        EthernetHeader_t xEthernetHeader; /**< UDP-Packet ethernet header  0 + 14 = 14 */
        IPHeader_t xIPHeader;             /**< UDP-Packet IP header        14 + 20 = 34 */
        UDPHeader_t xUDPHeader;           /**< UDP-Packet UDP header       34 +  8 = 42 */
    #include "pack_struct_end.h"
    typedef struct xUDP_PACKET UDPPacket_t;
I’ve included the IAR pack_struct files included in TCP library.
Are you using the IAR specific file? FreeRTOS-Plus-TCP/pack_struct_end.h at main · FreeRTOS/FreeRTOS-Plus-TCP · GitHub
Yes, I am. This is the preprocessor output of this struct:
__packed
    struct xUDP_PACKET
I created an IAR project with FreeRTOS+TCP and I am able to repro this warning. I have also verified the preprocessor output and this seems like an incorrect warning from the compiler. If I remove the semi-colon from the pack_struct_end.h, it results in an error confirming that the compiler does see the semi colon.
So we can conclude that this warning is not important and you can safely suppress it.
I have the same issue with Keil compiler. How i can resolve it?
I guess this conclusion should be applicable and you should suppress this warning.
Thank you, but in pack_struct_start.h i see the supress command or not?
#pragma GCC diagnostic ignored “-Wpragma-pack”
The ARM compiler used by Keil changed from GCC to LLVM at version 6. There are a number of differences including the diagnostic suppression syntax.
https://developer.arm.com/documentation/100068/0621/Migrating-from-Arm-Compiler-5-to-Arm-Compiler-for-Embedded-6/Migration-overview?lang=en
I use gcc compiler 5.06 i suppouse tcp library build with 6 version?
If I am looking in the correct place, the documentation around 5.06 indicates a different #pragma for suppression.
https://developer.arm.com/documentation/dui0375/g/Compiler-Diagnostic-Messages/Controlling-compiler-diagnostic-messages-with-pragmas?lang=en
