There is cpu load API “vTaskGetCpuLoadStats” in kernel v9.0.0. But I can’t find it in kernel v10.3.1.
Has it been deleted now?
void vTaskGetCpuLoadStats( char *pcWriteBuffer )
TaskStatus_t *pxTaskStatusArray;
volatile UBaseType_t uxArraySize, x;
uint64_t ulTotalTime;
#if( configUSE_TRACE_FACILITY != 1 )
#error configUSE_TRACE_FACILITY must also be set to 1 in FreeRTOSConfig.h to use vTaskGetRunTimeStats().
* PLEASE NOTE:
* This function is provided for convenience only, and is used by many
* of the demo applications. Do not consider it to be part of the
* scheduler.
* vTaskGetCpuLoadStats() calls uxTaskGetSystemState(), then formats part
* of the uxTaskGetSystemState() output into a human readable table that
* displays the amount of time(0.1s/1s/10s) each task has spent in the
* Running state in percentage term.
* vTaskGetCpuLoadStats() has a dependency on the sprintf() C library
* function that might bloat the code size, use a lot of stack, and
* provide different results on different platforms. An alternative,
* tiny, third party, and limited functionality implementation of
* sprintf() is provided in many of the FreeRTOS/Demo sub-directories in
* a file called printf-stdarg.c (note printf-stdarg.c does not provide
* a full snprintf() implementation!).
* It is recommended that production systems call uxTaskGetSystemState()
* directly to get access to raw stats data, rather than indirectly
* through a call to vTaskGetRunTimeStats().
/* Make sure the write buffer does not contain a string. */
*pcWriteBuffer = 0x00;
/* Take a snapshot of the number of tasks in case it changes while this
function is executing. */
uxArraySize = uxCurrentNumberOfTasks;
/* Allocate an array index for each task. NOTE! If
configSUPPORT_DYNAMIC_ALLOCATION is set to 0 then pvPortMalloc() will
equate to NULL. */
pxTaskStatusArray = pvPortMalloc( uxCurrentNumberOfTasks * sizeof( TaskStatus_t ) );
if( pxTaskStatusArray != NULL )
/* Generate the (binary) data. */
uxArraySize = uxTaskGetSystemState( pxTaskStatusArray, uxArraySize, &ulTotalTime );
/* Create a human readable table from the binary data. */
for( x = 0; x < uxArraySize; x++ )
/* Write the task name to the string, padding with
spaces so it can be printed in tabular form more
easily. */
pcWriteBuffer = prvWriteNameToBuffer( pcWriteBuffer, pxTaskStatusArray[ x ].pcTaskName );
#ifdef portLU_PRINTF_SPECIFIER_REQUIRED
sprintf( pcWriteBuffer, "\t%lu%%\t%lu%%\t%lu%%\r\n",
pxTaskStatusArray[ x ].xCpuLoad.ulAveragePoint1s,
((pxTaskStatusArray[ x ].xCpuLoad.ulAverage1s + 5) / 10),
(( pxTaskStatusArray[ x ].xCpuLoad.ulAverage10s +50) /100));
#else
/* sizeof( int ) == sizeof( long ) so a smaller
printf() library can be used. */
sprintf( pcWriteBuffer, "\t%2u%%\t%2u%%\t%2u%%\r\n",
(unsigned int) pxTaskStatusArray[ x ].xCpuLoad.ulAveragePoint1s,
(unsigned int) ((pxTaskStatusArray[ x ].xCpuLoad.ulAverage1s + 5) / 10),
(unsigned int) ((pxTaskStatusArray[ x ].xCpuLoad.ulAverage10s +50) /100));
pcWriteBuffer += strlen( pcWriteBuffer );
/* Free the array again. NOTE! If configSUPPORT_DYNAMIC_ALLOCATION
is 0 then vPortFree() will be #defined to nothing. */
vPortFree( pxTaskStatusArray );
mtCOVERAGE_TES**strong text**T_MARKER();
#endif /* ( ( configGENERATE_RUN_TIME_STATS == 1 ) && ( configUSE_STATS_FORMATTING_FUNCTIONS > 0 ) ) */
