Hi, i’m working on STM32CubeIDE platform to program STM32F407 Discovery Kit with FreeRTOS. I set the default configuration of FREERTOS and I select TIM1 as Timebase Source as suggested. I want to test a simple blinking LED routine in the default task, but during debug the software generates Hard Fault Exception on osKernalStart() call. The exception is generated here:
void vPortStartFirstTask( void )
__asm volatile(
" ldr r0, =0xE000ED08 \n" /* Use the NVIC offset register to locate the stack. /
" ldr r0, [r0] \n"
" ldr r0, [r0] \n"
" msr msp, r0\n" / Set the msp back to the start of the stack. /
" cpsie i\n" / Globally enable interrupts. /
" svc 0\n" / System call to start first task. */
" nop\n"
I have read in other posts the problem could be solved by adding these lines, but in my version of FreeRTOS and STM32CubeIDE they were already present.
Any suggestions?
Thanks for helping.
Riccardo Palma, Giacomo Melai
