There is a problem on Cortex-M0 that interrupts have to be enabled to call SVC to in turn start the scheduler so there is an instruction during which interrupt are enabled and the scheduler is not started. What can be done about this?
On the M3 system interrupts are not enabled until the first task context is restored. That is possible because it uses the basepri, but there is no basepri on the m0.
For the code you post it looks like you are using an out of date FreeRTOS version, although I don’t think that is related to your problem.
Try replacing the code in prvStartFirstTask() (vPortStartFirstTask() in your case) with the following. It starts the scheduler without using the SVCHandler, so interrupts can remain disabled until the task context is ready:
/* The MSP stack is not reset as, unlike on M3/4 parts, there is no vector
table offset register that can be used to locate the initial stack value.
Not all M0 parts have the application vector table at address 0. */
ldr r3, =pxCurrentTCB /* Obtain location of pxCurrentTCB. */
ldr r1, [r3]
ldr r0, [r1] /* The first item in pxCurrentTCB is the task top of stack. */
adds r0, #32 /* Discard everything up to r0. */
msr psp, r0 /* This is now the new top of stack to use in the task. */
movs r0, #2 /* Switch to the psp stack. */
msr CONTROL, r0
pop {r0-r5} /* Pop the registers that are saved automatically. */
mov lr, r5 /* lr is now in r5. */
cpsie i /* The first task has its context and interrupts can be enabled.*/
pop {pc} /* Finally, pop the PC to jump to the user defined task code. */
yes this happens some times when i am resetting the controller using system reset. this not happening at every startup
NVIC_SystemReset() is an arm core API used to reset the controller. In this we are writing in AIRCR (Application Interrupt and Reset Control Register) which in turn request for an system soft reset…
If that means on a power on reset, then I don’t know what could be causing the problem. Does it happen even when no interrupts are enabled before the scheduler is started?
