Hi.
I have problem with HardFault in my app.
Demos will execute on my hardware.
Descritpion of problem:
I have Task1 which wait for queue from antoher Task2 (1Byte length). (On SPI Rx, My input, Slave output).
In Task1, I use pvPortMalloc to allocate memory to save incoming packet (Always 30 bytes).
During execution program Task1 runs correctly, but after a few times of execution I get HardFault.
Follow the instruction from : https://www.freertos.org/Debugging-Hard-Faults-On-Cortex-M-Microcontrollers.html
I check pc counter, and in disassembly, i find that HardFault occured in
Are you 100% sure the priority of your SPI interrupt is at or below
configMAX_SYSCALL_INTERRUPT_PRIORITY? Often people are sure, then find
out its not, because it is actually complex on the Cortex-M to
understand how priority bits get shifted around. My recommendation be
to update to the very latest release of FreeRTOS 10.1.x, then ensure
configASSERT() is defined - as that will trap nearly all, if not all,
interrupt priority configuration issues. I think the V8.x code will
trap some, but not all.
Thanks for reply, the problem was fixed by invert memory allocation in time, but i dont find what cause a problem. It seems that @Richar Barry have rigtht. Now i find that pvPortMalloc allocate memory at adress 0x10(RAM started at 0x20000000, 0x10 is boot memory) . I m surely dont having memory leak, configUSE_MALLOC_FAILED_HOOK is set to 1, vApplicationMallocFailedHook is never called by the FreeRTOS. It seems system think that memory allocation works correctly.
malloc giving bad memory addresses tends to come from one of two sources, one is having improper frees, either freeing a block twice, with a wrong address, or memory that wasn’t allocated with malloc; or if some piece of code writes to memory outside an allocation block.
