abuteir wrote on Thursday, July 29, 2010:
If I stopped the interrupt after start the schedule. What will be effect of the Freertos .
The follwing code from tasks.c .
In anther Worde if I deleted the code line ‘portDISABLE_INTERRUPTS();’ what will be happened?
void vTaskStartScheduler( void )
portBASE_TYPE xReturn;
/* Add the idle task at the lowest priority. */
xReturn = xTaskCreate( prvIdleTask, ( signed char * ) "IDLE", tskIDLE_STACK_SIZE, ( void * ) NULL, ( tskIDLE_PRIORITY | portPRIVILEGE_BIT ), ( xTaskHandle * ) NULL );
if( xReturn == pdPASS )
/* Interrupts are turned off here, to ensure a tick does not occur
before or during the call to xPortStartScheduler(). The stacks of
the created tasks contain a status word with interrupts switched on
so interrupts will automatically get re-enabled when the first task
starts to run.
STEPPING THROUGH HERE USING A DEBUGGER CAN CAUSE BIG PROBLEMS IF THE
DEBUGGER ALLOWS INTERRUPTS TO BE PROCESSED. */
xSchedulerRunning = pdTRUE;
xTickCount = ( portTickType ) 0;
/* If configGENERATE_RUN_TIME_STATS is defined then the following
macro must be defined to configure the timer/counter used to generate
the run time counter time base. */
portCONFIGURE_TIMER_FOR_RUN_TIME_STATS();
/* Setting up the timer tick is hardware specific and thus in the
portable interface. */
if( xPortStartScheduler() )
/* Should not reach here as if the scheduler is running the
function will not return. */
/* Should only reach here if a task calls xTaskEndScheduler(). */
