Problem 1:
I have been facing some issue with vApplicationTickHook, if I call uart_printf inside this function, then in start it schedule tasks two-three times after it does not schedule tasks. It only goes inside vApplicationTickHook. If I comment uart_printf then everything work fine.Please tell me why it is happening? Even my tick interrupt 100ms and uart_printf using 115200 baud rate (polling mode) and I am sending 4 (“Tick”)charaters, so I think it is not the case of nested interrupt or tick miss.
int
main(int argc, char* argv[])
// At this stage the system clock should have already been configured
// at high speed.
// Infinite loop
while (1)
/* Configure the hardware ready to run the test. */
prvSetupHardware();
xTaskCreate(vApplicationTaskTest, "TestTask", configMINIMAL_STACK_SIZE, (void * ) NULL, tskIDLE_PRIORITY+1UL, NULL);
xTaskCreate(vApplicationTaskTest2, "TestTask2", configMINIMAL_STACK_SIZE, (void * ) NULL, tskIDLE_PRIORITY+1UL, NULL);
/* Start the scheduler. */
vTaskStartScheduler();
/* Should never be reached */
for( ;; ); }
#pragma GCC diagnostic pop
static void prvSetupHardware( void ){
/* Setup STM32 system (clock, PLL and Flash configuration) */
SystemInit();
* Callbacks/Hooks
void vApplicationTickHook( void ){
uart_printf("Tick");
// NOTE: if I comment it then it works fine
void vApplicationIdleHook( void ){
uart_printf("Entered vApplicationIdleHook\n");
void vApplicationMallocFailedHook( void ){
uart_printf("Entered vApplicationMallocFailedHook\n");
for(;;);
void vApplicationStackOverflowHook( TaskHandle_t pxTask, char *pcTaskName){
( void )pxTask;
( void )pcTaskName;
for(;;);
* Tasks
void vApplicationTaskTest( void *pvParameters){
while(1){
uart_printf("In Task vApplicationTaskTest\n");
void vApplicationTaskTest2( void *pvParameters){
while(1){
uart_printf("\tIn Task vApplicationTaskTest2\n");
}`Preformatted text`
Output Seriar Terminal:
Tick
Tick
Tick
Tick
Tick
Tick
…goes on
Problem 2:
If I put uart_printf in between critical section (enable and disable Irq) of vApplicationTickHook and other two task, then it works fine. Even I am call uart_printf inside vApplication, as mentioned below code.
int
// at high speed.
// Infinite loop
while (1)
prvSetupHardware();
for( ;; ); }
SystemInit();
* Callbacks/Hooks
__disable_IRQ();
__enable_IRQ();
for(;;);
( void )pxTask;
( void )pcTaskName;
for(;;);
* Tasks
while(1){
__disable_IRQ();
__enable_IRQ();
`void vApplicationTaskTest2( void *pvParameters)`
while(1){
__disable_IRQ();
__enable_IRQ();
Problem 3:
If I use trace_printf (system call over debugger) instead of serial uart then it works fine. Even I think trace_printf slower than uart serial.
Please help me to figure out how to debug this problem and why it is happening
