system
                (system)
              1
              karsten_klein wrote on Monday, January 12, 2009:
I have the following code:
void vApplicationIdleHook( void )
unsigned short temp;
unsigned short  queuemessage;
if (xQueueReceive(xQueueExtEepromApl2Idle,  &queuemessage, 1))
    temp = 2;    /* for test */
    temp = 1;        /* for test */
The call of the function "xQueueReceive" causes an "Bus Error Data Fetch" - exception.
If i use the same in any other Task, everything seams to be fine.
Is it not possible to use the queues inside the vApplicationIdleHook() ?
Very you very much in advance
Regards
Karsten
                system
                (system)
              2
              davedoors wrote on Monday, January 12, 2009:
You cannot make a blocking function call in the idle hook. If you change the last parameter to 0 it will work. 0 means don’t block to wait for data.
              richard_damon wrote on Monday, January 12, 2009:
The Idle task is not allowed to block.
The Idle hook runs as part of the Idle task
xQueueReceive, unless given a 0 timeout parameter might block, violating the above rule.
If Idle blocks, suddenly there is no task to run and schedule dies.
                system
                (system)
              4
Ok, I see.
But does it work reliable if the xTicksToWait will be changed to 0 ?
