westmorelandeng wrote on Thursday, May 26, 2016:
Hello Richard,
Updated via SVN (actually yesterday) - version 9.0 is the same as RC2 - correct?
Thanks,
John W.
Hello Richard,
Thanks,
John W.
rtel wrote on Thursday, May 26, 2016:
The differences between V9.0.0rc2 and the final V9.0.0 release are noted
at the top of the following page:
http://www.freertos.org/History.txt
OK - I guess I should have said the kernel files - I diffed those before I posted and only got the header change as the difference.
Thanks,
John
As per the history.txt file, the kernel files have changed from the rc2
code - perhaps previously you were using the head revision from the
repository rather than the rc2 release?
Yes - I was using the tip of tree or the head version - you are right about that.
Thanks,
John
