I am pretty new at this but I found two ‘problems’ with the v9 code.
In the FreeRTOS.h file there are two instances of #ifndef configMAX_PRIORITIES. The second instance is not actually verifying the value.
Just before line 1906 of tasks.c I had to add a line #if ( configGENERATE_RUN_TIME_STATS == 1 ) with an #endif following line 1906 in order to compile.
Thank you for taking the time to provide this feedback.
The second instance of configMAX_PRIORITIES has been changed to:
#if configMAX_PRIORITIES < 1
I think your second issue is probably a misconfiguration, and could have been corrected by simply removing the definition of portCONFIGURE_TIMER_FOR_RUN_TIME_STATS from your FreeRTOSConfig.h file - but as per John W’s post, without seeing your FreeRTOSConfig.h file I can’t be sure.
#error Missing definition: configMAX_PRIORITIES must be defined in FreeRTOSConfig.h. See the Configuration section of the FreeRTOS API documentation for details.
#elif configMAX_PRIORITIES < 1
#error configMAX_PRIORITIES must be defined to be greater than or equal to 1.
My other problem was indeed an improper FreeRTOSConfig.h file. I had copied it over from the CORTEX_Kinetis_K60_Tower_IAR demo project:
