I am pretty sure nothing has changed in that part of the code between version 7.2.0 and 7.3.0. Nonetheless I just tried the following code with both versions at got identical results:
volatile unsigned portBASE_TYPE uxHighWaterMark;
static void prvQueueSendTask( void *pvParameters )
portTickType xNextWakeTime;
const unsigned long ulValueToSend = 100UL;
/* FIRST CALL TO uxTaskGetStackHighWaterMark(). */
uxHighWaterMark = uxTaskGetStackHighWaterMark( NULL );
/* Initialise xNextWakeTime - this only needs to be done once. */
xNextWakeTime = xTaskGetTickCount();
for( ;; )
vTaskDelayUntil( &xNextWakeTime, mainQUEUE_SEND_FREQUENCY_MS );
xQueueSend( xQueue, &ulValueToSend, 0 );
/* SECOND CALL TO uxTaskGetStackHighWaterMark(). */
Ok - that is a different matter to your original posting. There must be an incompatibility between the state viewer version and the FreeRTOS version. Have you tried updating the StateViewer? That comes from High Integrity Systems, not me. You should be able to update it using the standard Eclipse update mechanism.
