Hi, I have several tasks. I am using the approach of vTaskDelayUntil to allow my tasks to begin at a periodic interval (vanilla Code taken from Mastering_the_FreeRTOS_Real_Time_Kernel-A_Hands-On_Tutorial_Guide). I have also implemented measuring the period at which the task is running, using a xTaskGetTickCount() as soon as the task begins to run, and subracting this from the previous iteration value. Under normal circumstances the measured period is equal to the ‘wait until time’. - so far so good. (I am doing this to detect if a task over runs, if there is a better way to do this please tell me).
I then introduced using the high tide diagnostic, uxTaskGetStackHighWaterMark. Once this was introduced, I occasionally get incorrect measured periods. (about 1% of the time).
Originally I checked all of the tasks stack depth inside the same task, and thought maybe there was some context switching happening. But I have now moved the check to each own task and I still see these occasional errors in measured period. The error values can be larger or smaller than the expected period.
On running some test, for a period of 200 (2ms @ 10uS tick)
I see 190, 220, 189, 211,212,189. etc.
I should say one further thing, is that I have changed the system tick to be 10uS rather than 1msec. Its not easy to go back and undo this due to the system.
I was wondering if there was something in the implementation in the uxTaskGetStackHighWaterMark that would cause the task timing to be slightly different sometimes.
e.g.
const TickType_t xDelay = pdMS_TO_TICKS( 2 );
while(1)
xStartTime = xTaskGetTickCount();
/* do the task stuff */
blah blah
/* Prove that task is running at expected rate /
TaskInterval = (xStartTime - LastRunTime);
LastRunTime = xStartTime;
if(TaskInterval != xDelay)
/ Here I see the occasional error */
/* Check the stack usage If I remove this line, I do not see errors */
WaterMark_u32 = uxTaskGetStackHighWaterMark(TaskConfig_as[TaskNr_u8].Handle_s);
vTaskDelayUntil( &xLastWakeTime, xDelay );
