Hi you all!
I’m pretty new for FreeRTOS (and embedded programming in general) so bear with me please
I’m using FreeRTOS V10 on STM32F03xxx, installed from STM32CubeMx.
I’m currently running 1 periodic task that is waiting for a queue feed to get unblocked.
A software timer callback is sending an enumerated value to the queue every pre-defined amount of time.
I wonder whether changing the notification method to xTaskNotifyWait, instead of QueueReceive will save me on RAM, and if so, how to implement it?
I’ve tried to simply call xTaskNotify in the timer’s callback and check that xTaskNotifyWait is equal to pdPASS to perform the task, but it doesn’t seems to work for me.
Any suggestions?
A snippet of my code:
void appFsmTimerCallback()
// appReqQueueEntry_T QueueEntry;
// // Clear the queue entry
// memset(&QueueEntry, 0, sizeof(appReqQueueEntry_T));
// // Set Timeout Request
// QueueEntry.AppRequestType = APP_CMD_TIMEOUT;
// // Queue the TIMEOUT request to indicate timeout
// xQueueSend(appReqQ, &QueueEntry, 10);
xTaskNotify(appTaskHandler, NULL, eNoAction);
portTASK_FUNCTION(appTask, pvParameters)
while(1)
apptasktimer=xTaskGetTickCount();
// if (xQueueReceive(appReqQ, &QueueEntry, 50) == pdTRUE)
if (xTaskNotifyWait(0, 0, NULL, portMAX_DELAY) == pdPASS)
QueueEntry.AppRequestType == APP_CMD_TIMEOUT;
switch(appState)
// My FSM code comes here
I have a separated function for task initialization:
ReturnCode_T appInit()
// CReate the APP FSM task
xTaskCreate(&appTask, "app", 100, NULL, 1, ( TaskHandle_t * ) &appTaskHandler);
// Create APP FSM input queue queue
appReqQ = xQueueCreate(2, sizeof(appReqQueueEntry_T *));
appTimerHandler = xTimerCreate("AppTimer", pdMS_TO_TICKS(100), pdTRUE, 0, appFsmTimerCallback);
xTimerStart(appTimerHandler, 10);
and the typedef enum (for the “full picture”):
typedef enum{
APP_CMD_START,
APP_CMD_ABORT,
APP_CMD_TIMEOUT,
APP_CMD_ISR_COMPLETED
} AppReq_T;
Hope to found an answer here.
Thank you very much in advance!
In the end the notification value is a 32 bit value…
