system
(system)
1
nobody wrote on Tuesday, April 26, 2005:
Hello!
I am getting compiler errors when trying to use vTaskDelayUntil(), the errors comes from task.h and says:
identifier "pdTASK_CODE" is undefined
When not using delay function the task compiles correctly, any suggestions?? Thanks!
/Marcus B
system
(system)
2
Actually, this occurs when including "task.h" in the header-file, which is required to use vTaskDelayUntil()…
system
(system)
3
Include projdefs.h BEFORE task.h.
I think there was something in v3 that was going to change this.
system
(system)
4
Thanks! That helped!
/Marcus B
