SPIWP:0xee
mode:DIO, clock div:1
load:0x3fce3818,len:0x1758
load:0x403c9700,len:0x4
load:0x403c9704,len:0xc00
load:0x403cc700,len:0x2e04
entry 0x403c9908
I (26) boot: ESP-IDF v5.1.2-dirty 2nd stage bootloader
I (27) boot: compile time May 28 2024 11:41:09
I (27) boot: Multicore bootloader
I (30) boot: chip revision: v0.2
I (34) boot.esp32s3: Boot SPI Speed : 80MHz
I (39) boot.esp32s3: SPI Mode : DIO
I (44) boot.esp32s3: SPI Flash Size : 16MB
I (48) boot: Enabling RNG early entropy source...
I (54) boot: Partition Table:
I (57) boot: ## Label Usage Type ST Offset Length
I (65) boot: 0 nvs WiFi data 01 02 00009000 00006000
I (72) boot: 1 phy_init RF data 01 01 0000f000 00001000
I (80) boot: 2 factory factory app 00 00 00010000 00500000
I (87) boot: End of partition table
I (91) esp_image: segment 0: paddr=00010020 vaddr=3c100020 size=42534h (271668) map
I (148) esp_image: segment 1: paddr=0005255c vaddr=3fc99a00 size=04824h ( 18468) load
I (153) esp_image: segment 2: paddr=00056d88 vaddr=40374000 size=09290h ( 37520) load
I (163) esp_image: segment 3: paddr=00060020 vaddr=42000020 size=fa64ch (1025612) map
I (347) esp_image: segment 4: paddr=0015a674 vaddr=4037d290 size=0c754h ( 51028) load
I (368) boot: Loaded app from partition at offset 0x10000
I (368) boot: Disabling RNG early entropy source...
I (380) cpu_start: Multicore app
I (380) cpu_start: Pro cpu up.
I (380) cpu_start: Starting app cpu, entry point is 0x403756fc
0x403756fc: call_start_cpu1 at C:/Espressif/frameworks/esp-idf-v5.1.2/components/esp_system/port/cpu_start.c:157
I (0) cpu_start: App cpu up.
I (398) cpu_start: Pro cpu start user code
I (398) cpu_start: cpu freq: 160000000 Hz
I (398) cpu_start: Application information:
I (401) cpu_start: Project name: IR_BLE_mesh
I (406) cpu_start: App version: 3754d37-dirty
I (412) cpu_start: Compile time: May 28 2024 11:40:36
I (418) cpu_start: ELF file SHA256: e8dc3ceec165637f...
I (424) cpu_start: ESP-IDF: v5.1.2-dirty
I (429) cpu_start: Min chip rev: v0.0
I (434) cpu_start: Max chip rev: v0.99
I (439) cpu_start: Chip rev: v0.2
I (444) heap_init: Initializing. RAM available for dynamic allocation:
I (451) heap_init: At 3FCABDC8 len 0003D948 (246 KiB): DRAM
I (457) heap_init: At 3FCE9710 len 00005724 (21 KiB): STACK/DRAM
I (464) heap_init: At 3FCF0000 len 00008000 (32 KiB): DRAM
I (470) heap_init: At 600FE010 len 00001FD8 (7 KiB): RTCRAM
I (477) spi_flash: detected chip: gd
I (480) spi_flash: flash io: dio
W (485) ADC: legacy driver is deprecated, please migrate to `esp_adc/adc_oneshot.h`
I (494) sleep: Configure to isolate all GPIO pins in sleep state
I (500) sleep: Enable automatic switching of GPIO sleep configuration
I (507) coexist: coex firmware version: b6d5e8c
I (512) coexist: coexist rom version e7ae62f
I (517) app_start: Starting scheduler on CPU0
I (131) app_start: Starting scheduler on CPU1
I (522) main_task: Started on CPU0
I (532) main_task: Calling app_main()
I (536) [MAIN_DEBUG] : : =-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=
I (542) [MAIN_DEBUG] : : GWY00002 APPLICATION STARTED : 0.6
I (549) [MAIN_DEBUG] : : =-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=
I (555) [MESH_DEBUG] : Initializing...
I (555) gpio: GPIO[21]| InputEn: 1| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0
I (569) gpio: GPIO[14]| InputEn: 1| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0
I (578) gpio: GPIO[13]| InputEn: 1| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0
I (680) BLE_INIT: BT controller compile version [59725b5]
I (682) BLE_INIT: Bluetooth MAC: dc:da:0c:74:be:c2
I (683) phy_init: phy_version 620,ec7ec30,Sep 5 2023,13:49:13
I (791) [MESH_DEBUG] : Open namespace done, name "mesh_example"
E (792) [MESH_ERROR] : Gpio detect
E (796) [MESH_ERROR] : esp_ble_mesh_init
I (925) [MESH_DEBUG] : ESP_BLE_MESH_PROV_REGISTER_COMP_EVT, err_code 0
I (930) [MESH_DEBUG] : Restore, key "vendor_client", length 512
I (931) EXAMPLE_NVS: Restore, data: 07 00 00 00 67 00 90 6a 00 00 00 00 00 00 00 00
I (937) EXAMPLE_NVS: Restore, data: 00 00 00 00 00 00 00 00 4e 30 30 30 30 31 00 00
I (945) EXAMPLE_NVS: Restore, data: 07 00 00 00 e9 3d 42 06 00 00 00 00 00 00 00 00
I (953) EXAMPLE_NVS: Restore, data: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
I (962) EXAMPLE_NVS: Restore, data: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
I (970) EXAMPLE_NVS: Restore, data: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
I (979) EXAMPLE_NVS: Restore, data: 00 00 00 00 00 00 00 00 00 43 6f 6f 6c 00 00 00
I (987) EXAMPLE_NVS: Restore, data: 00 00 00 00 00 00 00 00 00 05 14 01 01 00 00 00
I (996) EXAMPLE_NVS: Restore, data: 00 00 00 1c 14 00 00 00 00 00 00 00 00 00 00 00
I (1004) EXAMPLE_NVS: Restore, data: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
I (1012) EXAMPLE_NVS: Restore, data: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
I (1021) EXAMPLE_NVS: Restore, data: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
I (1030) EXAMPLE_NVS: Restore, data: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
I (1038) EXAMPLE_NVS: Restore, data: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
I (1047) EXAMPLE_NVS: Restore, data: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
I (1055) EXAMPLE_NVS: Restore, data: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
I (1064) EXAMPLE_NVS: Restore, data: 00 00 00 00 69 00 01 00 00 00 02 00 03 00 05 00
I (1072) EXAMPLE_NVS: Restore, data: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
I (1081) EXAMPLE_NVS: Restore, data: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
I (1089) EXAMPLE_NVS: Restore, data: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
I (1098) EXAMPLE_NVS: Restore, data: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
I (1106) EXAMPLE_NVS: Restore, data: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
I (1115) EXAMPLE_NVS: Restore, data: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
I (1123) EXAMPLE_NVS: Restore, data: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
I (1132) EXAMPLE_NVS: Restore, data: 00 00 00 00 00 00 00 00 69 00 9c 16 00 00 00 00
I (1140) EXAMPLE_NVS: Restore, data: 00 00 00 00 69 00 fb 0f 00 00 00 00 00 00 00 00
I (1149) EXAMPLE_NVS: Restore, data: 00 00 00 00 00 00 00 00 4e 30 30 30 30 31 00 00
I (1157) EXAMPLE_NVS: Restore, data: 07 00 00 00 bf 54 4a 08 00 00 00 00 00 00 00 00
I (1166) EXAMPLE_NVS: Restore, data: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
I (1174) EXAMPLE_NVS: Restore, data: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
I (1183) EXAMPLE_NVS: Restore, data: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
I (1191) EXAMPLE_NVS: Restore, data: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
I (1200) [MESH_DEBUG] : Restore, server_addr 0x0007, vnd_tid 0x0000
E (1207) [MESH_ERROR] : esp_ble_mesh_init
I (1211) [MESH_DEBUG] : ESP_BLE_MESH_PROVISIONER_SET_DEV_UUID_MATCH_COMP_EVT, err_code 0
I (1226) [MESH_DEBUG] : ESP_BLE_MESH_PROVISIONER_PROV_ENABLE_COMP_EVT, err_code 0
W (1230) BLE_MESH: AppKey exists, AppKeyIndex updated
I (1234) [MESH_DEBUG] : ESP_BLE_MESH_PROVISIONER_ADD_LOCAL_APP_KEY_COMP_EVT, err_code 0
I (1243) [MESH_DEBUG] : ESP_BLE_MESH_PROVISIONER_BIND_APP_KEY_TO_MODEL_COMP_EVT, err_code 0
I (1252) [MESH_DEBUG] : ESP_BLE_MESH_PROVISIONER_BIND_APP_KEY_TO_MODEL_COMP_EVT, err_code 0
I (1261) [MESH_DEBUG] : ESP BLE Mesh Provisioner initialized
E (1268) [MESH_ERROR] : Gpio detect
I (1273) gpio: GPIO[7]| InputEn: 1| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0
I (1273) main_task: Returned from app_main()
I (1282) gpio: GPIO[7]| InputEn: 1| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0
I (1296) gpio: GPIO[7]| InputEn: 1| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0
I (1305) gpio: GPIO[7]| InputEn: 1| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0
I (1314) gpio: GPIO[7]| InputEn: 1| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0
I (1323) gpio: GPIO[7]| InputEn: 1| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0
I (1333) gpio: GPIO[7]| InputEn: 1| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0
I (1342) gpio: GPIO[7]| InputEn: 1| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0
I (1351) gpio: GPIO[7]| InputEn: 1| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0
I (1361) gpio: GPIO[7]| InputEn: 1| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0
I (1370) gpio: GPIO[7]| InputEn: 1| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0
I (1379) gpio: GPIO[7]| InputEn: 1| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0
I (1388) gpio: GPIO[7]| InputEn: 1| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0
I (1398) gpio: GPIO[7]| InputEn: 1| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0
I (1407) gpio: GPIO[7]| InputEn: 1| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0
I (1416) gpio: GPIO[7]| InputEn: 1| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0
I (1426) gpio: GPIO[7]| InputEn: 1| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0
I (1435) gpio: GPIO[7]| InputEn: 1| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0
I (1444) gpio: GPIO[7]| InputEn: 1| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0
I (1453) gpio: GPIO[7]| InputEn: 1| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0
I (1463) gpio: GPIO[7]| InputEn: 1| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0
I (1472) gpio: GPIO[7]| InputEn: 1| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0
I (1481) gpio: GPIO[7]| InputEn: 1| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0
I (1490) gpio: GPIO[7]| InputEn: 1| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0
I (1500) gpio: GPIO[7]| InputEn: 1| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0
I (1509) gpio: GPIO[7]| InputEn: 1| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0
I (1518) gpio: GPIO[7]| InputEn: 1| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0
I (1528) gpio: GPIO[7]| InputEn: 1| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0
I (1537) gpio: GPIO[7]| InputEn: 1| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0
I (1546) gpio: GPIO[38]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0
I (1274) gpio: GPIO[46]| InputEn: 1| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0
I (1567) gpio: GPIO[9]| InputEn: 1| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0
(1574465) [LTE_DEBUG] : Power cycling LTE starts
I (1274) gpio: GPIO[12]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0
(4181780) [LTE_DEBUG] : Power cycling LTE end
(4183166) [LTE_DEBUG] : TURN_OFF_ECHO_CMD
(4183903) [LTE_DEBUG] : Command sent : ATE0
(4186518) [LTE_DEBUG] : Heap Free size : 186348 bytes
