I am trying to use printf in FreeRTOS with MSP430FR5969 board.
I have tested with basic helloworld project without FreeRTOS,. and it works well.
But the CIO console is not showing up when I run the other project.
I stepped through the code and I can see that FreeRTOS includes its own version of printf and not the one that comes with the TI Compiler C runtime support library.
Does anybody knows how to use this printf library in MSP430 board?
I mean I would like to use printf which FreeRTOS provides, but it is not working in my MSP430 board.
So I wonder if there any manual about using printf that FreeRTOS provide.
You need to tell the printf() implementation how to output characters. That is done using the printchar() function, which is defined at the top of printf-stdarg.c. You need to implement the function to output the characters the function passes in using the function’s parameters. In a lot of cases that will be to simply write the characters to a serial port.
