Hello
I using FreeRTOS with TI ARM Cortex-R4F RM48 and keil.
But I do not see any project that using ARM Cortex-R4F with keil in Demo document.
So I want to ask how to transplant FreeRTOS to ARM Cortex-R4?
Which compiler are you using with Keil? If it is the ARM compiler then
you will probably need to actually create a port yourself. If it is GCC
or the TI compiler then you will have a good starting point with what is
already in the FreeRTOS kernel download.
TI also provide an R4 port of FreeRTOS that supports the MPU in their
HalCoGen tool (at least they used to) - does that generate projects for
the ARM tools?
