Hi all,
In my project i am using FreeRTOS 5.1.0 with Ride/GCC
Utilizing Queues and Semaphores within ISRs (DMA and USART) I have noticed that sometimes FreeRTOS "hang" in vListInsert, line 130. Unfortunately seems to be not predicatable and so it is hard to reproduce.
i am pretty sure that i am using the right APIs and interrupt priorities.
I have seen a similar problem in an old thread and one user was experiencing the same exact behavior: http://sourceforge.net/forum/message.php?msg_id=5168269
Object: “Queue Problem (solved’ish)”
Author: DaWorm
Date: 2008-08-14 14:36
I was wondering if you guys can have an idea of what is happening.
The most common cause of a hang on this line is a stack overflow. However, on the Cortex in particular another common cause is incorrect interrupt priority assignments (note interrupt priorities, not task priorities).
Basically - because the Cortex uses low numeric values to denote high priorities it is very easy to get assignments the wrong way around, and the diagram on the above referenced page would be the other way up (for the Cortex only).
Another think that can cause this is calling a blocking function from within a critical section.
Hi Richard and thank you very much.
Actually I am aware of the Cortex assigments of ISR priorities and i do not notice any stack overflow with the FreeRTOS "stack check" functionalities turned on.
Anyway, i will try some more testing. thanks for the hints.
However, i have another question probably of general interest regarding Interrupt priorities:
i am a little bit confused on two config lines in FreeRTOS:
#define configKERNEL_INTERRUPT_PRIORITY 255 #define configMAX_SYSCALL_INTERRUPT_PRIORITY 191 /* equivalent to 0xa0, or priority 5. */
how is the mapping from 0-15 in STM32 and FreeRTOS priorities?
