aresqi wrote on Tuesday, July 04, 2006:
hello richard
Do you kown protothread by Adam Dunkels? It’s similar to coroutine and is more mature, i think. May be we can expand coroutine based on that.
I have a way to use local variables in each coroutines.
1. we add a field of void * pVar in corCRCB and the initial value is NULL
2. when we enter a coroutine and if pVar is NULL , then we enter the coroutine first time , so we can malloc some space for our local variables. But how many space is machine and compiler dependent.
3. all local variable must use pointers which can point to a space return by malloc.
for example
void vACoRoutineFunction( xCoRoutineHandle xHandle, unsigned portBASE_TYPE uxIndex )
//define local variables here
//do it before crSTART
int *a,*b; //we need 2 int variables
void **c; //we need 1 void* variable
void *pMalloc
if (xHandle->pVar == NULL)
pMalloc = pvPortMalloc( (sizeof)int + (sizeof)int + (sizeof)(void *) );
if (pMalloc)
a = pMalloc;
b = pMalloc +1 //in 32bit machine
c = pMalloc +1 //in 32bit machine
xHandle->pVar = pMalloc;
pMalloc = xHandle->pVar;
a = pMalloc;
// Co-routines must start with a call to crSTART().
crSTART( xHandle );
for( ;; )
*a = 10;
// It is fine to make a blocking call here,
crDELAY( xHandle, 10 );
//we can use local variables now
if (*a == 10)
// Co-routines must end with a call to crEND().
crEND();
