I usually put the kick opration in idle hook, which will be done by idle task who is be set the lowest priority.the reson is :so much so that the lowest priority task be starved, a wtd reset required now.
And,I would take care of any opinion by others.
I found this is a FAQ in FreeRTOS. and i didn’t see any satisfying and simple measure.
I’m using a similar scheme because it’s good enough for my use case.
If you need to monitor the state of other/all tasks of your application you need to implement that yourself. A simple solution could be to check for changes of a heartbeat counter incremented by each task if they run periodically in the task/hook keeping the WDT alive.
This is what all the FreeRTOS demos do. Many of the demo tasks run tests - if a test fails it stops incrementing the heartbeat. If the task stalls or doesn’t get CPU time then the heartbeat stops by itself. A central monitoring task then looks at all the heartbeats - in your case if a heartbeat stops you can take appropriate action, which may be to stop kicking the WDT.
