Not quite sure what you are asking here. You have the design choice of handling USB events from the interrupt service routine if you want. If the event is going to take a long time to process then it is best to let a task perform the processing. Maybe you want some events processed directly in the ISR and some passed to a task.
Hello, I’m trying to do the same thing. Use an str711 with usb and IAR. What interrupt handlers do I need to include to get the usb to work, so far I only have an example of how to use the uart handler with freeRtos (that was included with the iar build)
