adiman1984 wrote on Monday, August 15, 2016:
I’ve been having some weird hard faults (usage faults) with a freeRTOS project running on an STM32F405 processor. I’m using GCC with Eclipse.
The issue I’m seeing is that I get a hard fault when a tasks blocks (queue, delay, etc.) and there is nothing else to run. I verified that my main task runs and then blocks on a queue, which then causes a contect switch to a lower-priority task. If this lower-priority task encounters a delay (vTaskDelay) or blocks on a semaphore, or queue, I get a hard fault. I even tried removing everything else and only run a single task with an empty structure and a time delay (vTaskDelay). Again, as soon as the delay is encountered, it fails.
I found that the exception occurs in the portYIELD_WITHIN_API function, specifially at the assembly line “dsb sy”. The link register points to the end of the xTaskResumeAll() function, which doesn’t really make sense to me…
I have configASSERT defined, stack overflow checking is turned on (2), system clock is propperly setup and is correct (verified), the systick ISR fires, and there isn’t an interrupt priority issue (no other ISRs active and no API calls from ISRs).
Any ideas what could cause this? Are there any specific initializations that are needed for the STM32F4 processors and/or the associated peripherals that I’m not aware of? I’ve been using freeRTOS successfully for 2 years on TI’s Tiva microcontrollers, which have a Cortex-M4 processor as well, so I’m well aware of all the pitfals of freeRTOS on ARM M4.
Any help would be greatly appreciated.
