So I already have a custom application that uses Amazon FreeRTOS as a component and it uses MQTT, OTA updates, Wifi provisioning via BLE… But now we want to do the Wifi provisioning via Access Point. I’ve seen that in the newer versions of FreeRTOS and ESP-IDF there’s some sort of support for this, although it’s a bit more buried than some of the other functionalities.
I’m trying to update my FreeRTOS folder or my ESP-IDF folder, but every time I do so I create a lot of conflicts, missing headers and undefined references. As an example, right now this is one of the conflicts I’m having:
../freertos/vendors/espressif/esp-idf/components/esp_http_server/src/httpd_main.c:16:24: fatal error: sys/socket.h: No such file or directory compilation terminated.
For context, I originally downloaded FreeRTOS from the Amazon console, so there’s no direct link to the github repository to automatically update, but I’ve tried cloning the repo and manually moving it where my project is but the ESP then has problems with reading wifi buffer descriptors. After trying this, I tried to download an example repo given here and moving my project on top of it, and here’s where I’m at right now, because that repo isn’t updated enough so the functionalities I need aren’t there.
I’ve also seen that in order to use this component from ESP-IDF I have to be using the lwip stack, but I haven’t seen how exactly can I configure this.
What’s the best way to update my project files and have lwip configured so I can use the Access Point mode?
