I am using Atmel SAM L21 Xplained pro A board, with Atmel Studio 7. I opened the demo project OLED1 XPRO example with the ASF(3.35.1) FreeRTOS module, which is v8.0.1.
The standard demo works perfectly. However, I want to use pdMS_TO_TICK() function, but it’s not defined, and it seems it was introduced in a later version of FreeRTOS which is not directly accesible from the ASF wizard in Atmel Studio 7.
What are the steps needed to update the FreeRTOS version to use v9 in Atmel Studio 7 for SAM L21 board?
Once Atmel studio has created the project you can just copy the latest
FreeRTOS source files and header files over the top of the same files in
the generated project.
I have done that replacement. I see there is still FreeRTOSConfig.h header, which was created by the demo for V8.0.1. There is no demo for SAML21 with v9.0.0 where I can copy this file from, only for SAMD20.
How should this file be updated so the OLED demo can function with V9?
Moreover, asf.h from the original demo calls several FreeRTOSheader files, and the ASF wizard shows only v8.0.1. Should something be updated in the ASF header or anywhere else, to configure the ASF to use v9?
That should be backward compatible.
There is no difference between the SAMD20 and SAML21 as far as the
FreeRTOS code goes, use the same port files on both.
I don’t know what the OLED demo is, presumably Atmel code.
You need to copy the V9 source (.c) and header (.h) files into the
project. Did you do that? If so, then they are the files being built.
Nothing in Atmel Studio will change, it won’t know you have updated the
files so may still say the old version.
I added the two declarations into timers.c and tasks.c respectively copying the code from the previous link, but I get same error. I noticed the prototype in tasks.c says:
