jwestmoreland wrote on Tuesday, May 16, 2006:
Richard,
After my target runs for awhile - I get a stoppage:
My call stack looks like this:
main()
prvIdleTask(_A_IE1(0x0)
[PC=Memory:0x3082]
In main:
vTaskStartScheduler();
// shouldn’t get past this point unless a task calls vTaskEndScheduler()
// Note - I have a breakpoint on this first NOOP but it doesn’t stop there
__no_operation();
__no_operation();
while (1) {
__no_operation();
__no_operation();
// I have a breakpoint on the 2nd NOOP (just above) and the debugger stops here.
// turn Debug LED’s on:
asm(“bis.b #0x80,&0x1d”);
asm(“bis.b #0x01,&0x1d”);
I run the Idle Hook as well - this (crash) doesn’t always happen either - but I assume all of my targets will eventually fail.
What are some reasons this can happen? I know this may seem a bit nebulous - but the Scheduler is exiting (even though the vTaskEndScheduler() function) - isn’t being called.
It seems that somehow the return address from the
vTaskStartScheduler(); call is getting popped into the PC and executed - or at least an address+2 or something.
From my linker map file:
DATA16_Z
Relative segment, address: 3082 - 3085 (0x4 bytes), align: 1
Segment part 5. Intra module refs: pvPortMalloc
LOCAL ADDRESS
xEnd 3082
I’m using heap_2.c as my memory manager:
/* xEnd is used to mark the end of the list of free blocks. */
I’m also saying that the IdleTask & Hook should yield - it seems this problem may be occurring during that.
Thanks In Advance,
John W.
