jdurand wrote on Wednesday, March 20, 2019:
I found if I accidentally use the same Task Handle for two tasks, things
don’t work right but the error isn’t caught.
rtel wrote on Wednesday, March 20, 2019:
If I understand correctly, you are suggesting that the handles be initialized before they are used so the kernel knows if they are fresh or not. Task handles are not initialized before they are used, they are in effect just varibles (actually pointers to the TCB when used inside the kernel code), so I’m not sure how the kernel would kno w if you re-use the handle for two things.
