amirsadig wrote on Monday, November 07, 2016:
i have beaglebone black board and i am tring to port it… i found some coding about context switch like
#define portRESTORE_CONTEXT() \
extern volatile void * volatile pxCurrentTCB; \
extern volatile unsigned portLONG ulCriticalNesting; \
/* Set the LR to the task stack. */ \
__asm volatile ( \
"LDR R0, =pxCurrentTCB \n\t" \
"LDR R0, [R0] \n\t" \
"LDR LR, [R0] \n\t" \
/* The critical nesting depth is the first item on the stack. */ \
/* Load it into the ulCriticalNesting variable. */ \
"LDR R0, =ulCriticalNesting \n\t" \
"LDMFD LR!, {R1} \n\t" \
"STR R1, [R0] \n\t" \
/* Get the SPSR from the stack. */ \
"LDMFD LR!, {R0} \n\t" \
"MSR SPSR, R0 \n\t" \
/* Restore all system mode registers for the task. */ \
"LDMFD LR, {R0-R14}^ \n\t" \
"NOP \n\t" \
/* Restore the return address. */ \
"LDR LR, [LR, #+60] \n\t" \
/* And return - correcting the offset in the LR to obtain the */ \
/* correct address. */ \
"SUBS PC, LR, #4 \n\t" \
( void ) ulCriticalNesting; \
( void ) pxCurrentTCB; \
in the following code we have switched to system mode (because the first task has 0x1F as SPSR)
but the next instruction read LR still from Supervisor Mode
LDR LR, [LR, #+60]
can someone tell how this happend. i expected after setting SPSR to 0x1F that LR point to banked LR of System mode and not of Supervisor Mode.
the LR in system mode has a dummy value like 0x0a0a0a0a.
