The problem is in the implement of ulTaskNotifyTake that it masked the interrupt in the critical section. And our interrupt handler will not be triggered and there is a deadlock.
ulTaskNotifyTake equal to ulTaskGenericNotifyTake
FreeRTOS-Kernel/blob/main/tasks.c
The deadlock is happen in this way.
- There is a task A which use ulTaskNotifyTake to get a notification from an interrupt B
- In ulTaskNotifyTake, the interrupts are masked. Source code showed bellow.
- The interrupt will never be delivered because it is masked. the vTaskNotifyGiveFromISR will not be called in the interrupt handler.
- Deadlock happen.
uint32_t ulTaskGenericNotifyTake( UBaseType_t uxIndexToWait,
BaseType_t xClearCountOnExit,
TickType_t xTicksToWait )
uint32_t ulReturn;
configASSERT( uxIndexToWait < configTASK_NOTIFICATION_ARRAY_ENTRIES );
taskENTER_CRITICAL();
/* Only block if the notification count is not already non-zero. */
if( pxCurrentTCB->ulNotifiedValue[ uxIndexToWait ] == 0UL )
/* Mark this task as waiting for a notification. */
pxCurrentTCB->ucNotifyState[ uxIndexToWait ] = taskWAITING_NOTIFICATION;
if( xTicksToWait > ( TickType_t ) 0 )
prvAddCurrentTaskToDelayedList( xTicksToWait, pdTRUE );
traceTASK_NOTIFY_TAKE_BLOCK( uxIndexToWait );
/* All ports are written to allow a yield in a critical
* section (some will yield immediately, others wait until the
* critical section exits) - but it is not something that
* application code should ever do. */
portYIELD_WITHIN_API();
The taskEnter_CRITICALA() masked the interrupt.
portYIELD_WITHIN_API(); supposed to be wakeup by the interrupt handler. But it could not as interrupt will not happen after portYIELD_WITHIN_API();
