ulTaskNotify has bellow sequence: yield in critical section
If we have a task calling ulTaskNotifyTake, will it cause some interrupt to be masked?
Is this the expected behavior?
For a situation, we have an IRQ, and in the IRQ handler, we call xTaskGenericNotifyFromISR to wake up the task which is waiting on ulTaskNotifyTake. Then the problem is ulTaskNotifyTake will prevent the IRQ, and causes lock?
Source code for reference
uint32_t ulTaskNotifyTake( BaseType_t xClearCountOnExit, TickType_t xTicksToWait )
uint32_t ulReturn;
taskENTER_CRITICAL();
/* Only block if the notification count is not already non-zero. */
if( pxCurrentTCB->ulNotifiedValue == 0UL )
/* Mark this task as waiting for a notification. */
pxCurrentTCB->ucNotifyState = taskWAITING_NOTIFICATION;
if( xTicksToWait > ( TickType_t ) 0 )
prvAddCurrentTaskToDelayedList( xTicksToWait, pdTRUE );
traceTASK_NOTIFY_TAKE_BLOCK();
/* All ports are written to allow a yield in a critical
section (some will yield immediately, others wait until the
critical section exits) - but it is not something that
application code should ever do. */
portYIELD_WITHIN_API();
taskENTER_CRITICAL
#define taskENTER_CRITICAL() portENTER_CRITICAL()
#define portENTER_CRITICAL() vPortEnterCritical();
void vPortEnterCritical( void )
/* Mask interrupts up to the max syscall interrupt priority. */
uxPortSetInterruptMask();
**FreeRTOSConfig.h**
/* Interrupts that are assigned a priority above
* configMAX_API_CALL_INTERRUPT_PRIORITY (which in the GIC means a numerical
* value below configMAX_API_CALL_INTERRUPT_PRIORITY) cannot call any FreeRTOS
* API functions, will nest, and will not be masked by FreeRTOS critical
* sections
#define configMAX_API_CALL_INTERRUPT_PRIORITY 18
UBaseType_t uxPortSetInterruptMask( void )
uint32_t ulReturn;
/* Interrupt in the CPU must be turned off while the ICCPMR is being
updated. */
portDISABLE_INTERRUPTS();
if( portICCPMR_PRIORITY_MASK_REGISTER == ( uint32_t ) ( configMAX_API_CALL_INTERRUPT_PRIORITY << portPRIORITY_SHIFT ) )
/* Interrupts were already masked. */
ulReturn = pdTRUE;
ulReturn = pdFALSE;
portICCPMR_PRIORITY_MASK_REGISTER = ( uint32_t ) ( configMAX_API_CALL_INTERRUPT_PRIORITY << portPRIORITY_SHIFT );
__asm volatile ( "dsb sy \n"
"isb sy \n" ::: "memory" );
portENABLE_INTERRUPTS();
return ulReturn;
Just for clarification: You’re using xTaskNotifyFromISR in the ISR as documented ? Note the FromISR suffix for all FreeRTOS calls usable in ISRs. xTaskGenericNotify is an internal function and never used directly.
Critical sections in FreeRTOS code might cause minimal delays of ISR invocations but no deadlocks.
Also do you have configASSERT defined for development along with stack overflow checking ?
Yes. Forget to mention. xTaskGenericNotifyFromISR is used in IRQ handler.
Also from the code, for the case I mentioned above, if IRQ priority is above configMAX_API_CALL_INTERRUPT_PRIORITY (18), the interrupt may happen and the flow may work.
But if the IRQ priority is lower than configMAX_API_CALL_INTERRUPT_PRIORITY, then lockup will happen?
* sections
it is not permissable for a task to call a function that may suspend the task with the critical section claimed. That is necessarily a deadlock. Claiming the critical section basically means stalling all OS activity, including the scheduler.
You may fall into the fallacy here that with the critical section in effect, portYIELD_WITHIN_API() will NOT invoke the scheduler immediately because the service interrupt will not execute with interrupts disabled but will be deferred until interrupts are re-enabled (critical section left) AND no higher level priority interrupts are pending. That’s the very architecture of the scheduler.
taskENTER_CRITICAL: it just mask IRQ, it won’t mask SVC call (???)
portYIELD_WITHIN_API==>svc 0 ==> Triger exception IMMEDIATELY ==>FreeRTOS_SWI_Handler is called for task switch
My puzzle is from above code sequence, the scheduler is called immediately by portYIELD_WITHIN_API which is “svc 0” and will trigger exception immediately. (and interrupt disabling can’t mask “svc 0”)
Please correct me if something of my understanding is wrong. Thanks
* FreeRTOS_SWI_Handler handler is used to perform a context switch.
.align 8
.type FreeRTOS_SWI_Handler, %function
FreeRTOS_SWI_Handler:
/* Save the context of the current task and select a new task to run. */
portSAVE_CONTEXT
#if defined( GUEST )
MRS X0, ESR_EL1
#else
MRS X0, ESR_EL3
LSR X1, X0, #26
CMP X1, #0x15 /* 0x15 = SVC instruction. */
#else
CMP X1, #0x17 /* 0x17 = SMC instruction. */
B.NE FreeRTOS_Abort
BL vTaskSwitchContext
portRESTORE_CONTEXT
FreeRTOS_Abort:
/* Full ESR is in X0, exception class code is in X1. */
B .
We have problem in our application and this is one suspect area, but not confirmed yet.
We got the point Rac mentioned, but not fully align with the code. Also tried to understand if “svc 0” is deferred by taskEnter_Critical, but didn’t get any document for “svc 0” behavior.
We are using the port from FreeRTOS-Kernel/portable/GCC/ARM_CA53_64_BIT/, the yield is a “svc 0” call.
This one reads that the SVC instruction “causes an exception.” I read this to mean that this is subject to the standard Cortex A9 exception handling which is documented in the “ARM Generic Interrupt Controller Architecture Specification” which you can download from ARM.
Note that the ability to schedule instead of unconditionally invoke an exception handler is at the very heart of each and every processor architecture. Without this, you were right; we would necessarily deadlock. If the SVC would indeed immediately and unconditionally invoke the handler with disregard to priorities and interrupt mask, we wouldn’t need an interrupt in the first place, though. We might as well call a subroutine.
Ok - there is a problem and you suspect that the FreeRTOS portable layer is the reason ?
Could you explain what exactly the problem is ?
Besides that could you add which FreeRTOS version on which hardware you’re using ?
Let me clarify. We using the code from https://github.com/FreeRTOS/FreeRTOS-Kernel.
What I talked above is from folder portable/GCC/ARM_CA53_64_BIT. It is a portable part for Cortex A53 core with AARCH64
In the code:
taskENTER_CRITICAL: it just mask IRQ, it won’t affect SVC call (right?)
portYIELD_WITHIN_API==>svc 0 ==> Triger exception==>FreeRTOS_SWI_Handler is called for task switch (it is my understanding)
This is my understanding.
BTW, what is this #ifdef GUEST all about?
GEUST means it is running in EL1. For our case, GUEST is true/defined
but such as on CA9, the volunteer yield operation is done through “svc” call, which would step into svc flow directely and do the swich at once, i did not see any condition would block this switch,
it seems the swith would happed and success on CA9 port., which meas voluteer yiled could be done in “taskENTER_xxxx” and “taskEXIT_xxxx” region.
If this WAS true, then you were right; there’d be an immediate deadlock. Yet I’m almost positive your understanding is wrong. If this would be an unconditional jump to the ISR, it would completly bypass the exception handling architecture. Also there wouldn’t be a point in the SVC call; it would be exactly like a bl, possibly switching processor states.
It’s fairly easy to verify this: Set a breakpoint to the SVC call in the disassembly window, then do a single step. Do this with and without the critical section active. I’m almost 100% sure that in the first scenario, it’ll very simply jump over the instruction onto the next one and enter the context switch ISR only after the critical section is left, whereas in the second scenario, you’ll be right at the ISR. If that wasn’t the case, nothing would work because the scheduler crucially depends on the deferred invocation mechanism.
Let’s get on the same page: Your ISR isn’t (never ?) triggered and you think this is root caused by the ulTaskNotifyTake internal implementation ?
That would mean that the ARM_CA53_64_BIT FreeRTOS port is fundamentally broken… to be honest I can’t imagine that this got slipped through the FreeRTOS release tests.
Is there any other possible reason why the ISR is not triggered as expected ?
It is very helpful to mention which port you are using in your original post. Another tip is to say what your problem actually is, rather than something about a workaround or investigation into the problem.
The FreeRTOS code is portable across more than 40 architectures - so it won’t be a surprise it has to cope with many different context switch mechanisms. On very simple architectures it can just be a function call - but generally there are two classes: Synchronous and asynchronous.
When it is asynchronous, a context switch is requested by pending a low priority interrupt. If that is done inside a critical section then the interrupt remains pending until the critical section is exited, so context switches only ever happen when interrupts are enabled (or unmasked if interrupts are never globally disabled).
When it is synchronous, as in your case where an SVC is used, then the context switch will occur immediately whether you are inside a critical section or not. In those cases the kernel stores the critical section nesting depth as part of the task’s context. If a task switches out form within a critical section (so with interrupts masked), the next time it is switched back in interrupts will again be disabled again (when the critical nesting depth gets restored) before it starts to run - then it will exit the critical section to re-enable interrupts. The net effect is therefore the same as for the asynchronous method but the context switch occurs the other side of exiting the critical section. Likewise if a task switches out with interrupts enabled, the next time it is switched in interrupts will again be enabled even if it switched from a task that had interrupts disabled. The kernel is designed to work like this - it is not recommended for application code to yield in a critical section!
If you are running at EL1, one thing to watch out for is the interrupt priority view of a non-secure group 1 interrupt. The following is from the GIC doc:
For Non-secure writes to a priority field of a Non-secure Group 1 interrupt, before storing the value:
• The value is right-shifted by one bit.
• Bit [7] of the value is set to 1.
This translation means the priority value for the Non-secure Group 1 interrupt is in the bottom half of the priority range.
If your hardware implements 5 priority bits (32 unique priorities) and you want to set a non-secure group 1 interrupt’s priority to 18 (it can be greater than 16 only to ensure that it is in the bottom half range), you should use the following value:
Want to make it clear. Let’s say we use Cortex A53 port which uses “svc 0” to yield
You mentioned
The call ulTaskNotifyTake from APP will have this situation, and is not recommended to use from APP? Am I right?
If it is not the case, do you think bellow usage model is the correct way?
Any IRQ priority settings should be taken care?
Task thread (bottom half of the IRQ):
IRQ_bottom_half_task()
while (true) {
ulTaskNotifyTake(pdTRUE, portMAX_DELAY)
/* We get the notification from ISR, and do the remaining thing here */
IRQ_handler
my_irq_isr()
/* Get an IRQ, and notify the bottom half task */
xTaskGenericNotifyFromISR()
No. The official FreeRTOS API can be used, of course.
You just shouldn’t call (undocumented) portYIELD_WITHIN_API directly in your application code.
BTW Instead of using undocumented call to xTaskGenericNotifyFromISR I’d recommend to stick to the official API like xTaskNotifyFromISR.
