rtel wrote on Wednesday, May 16, 2007:
The page size is probably something to do with the uIP buffer configuration.
I’m not sure why you would have ping requests ignored. I have found it to be robust. Pings don’t use much of the uIP code to process, so this is unlikely to be a configuration problem. How much data are you pinging?
Are you using it on a high traffic network? I have only tested it in my office environment which, where there is not too much Ethernet traffic.
Regards.
