I am trying to run the STR912x uIP demo on the STR910-EVAL board. It seems that I am never able to get past the ComPort initialization/test tasks. I get the error: "check status flags 0x10".
On UART2 the alphabet is transmitted in an infinite loop. What must I do to proceed?
Unless there is anything different to the STR9 demos to any of the other demos, I would guess that you need a loop back connector on the com port. A paper clip usually does the trick. Just connect pins 2 and 3 together.
I also suggest you read the documentation page for the STR9 on the FreeRTOS WEB site.
