system
(system)
July 25, 2016, 7:55am
1
rasty1 wrote on Monday, July 25, 2016 :
I’m trying to optimize a footprint and reduce size of Ram disk, but get error if I define it smaller than 3 mb.
Image contains backtrace, place where it fails and some local variables.
I’d appreciate any idea.
https://rslutsker-gmail.tinytake.com/sf/ODUzNjA5XzM3MTEwMTE
Thanks
Rasty
system
(system)
July 25, 2016, 7:58am
2
Backtrace and variables
rtel
(Richard Barry)
July 25, 2016, 10:16am
3
rtel wrote on Monday, July 25, 2016 :
FAT imposes some minimum volume sizes. For example see the following
thread: http://superuser.com/questions/74392/minimum-volume-size-for-fat16
The minimum size for FAT12 is smaller.
system
(system)
July 25, 2016, 11:28am
4
How can I force it to use FAT12?
htibosch
(Hein Tibosch)
July 25, 2016, 8:19pm
5
heinbali01 wrote on Monday, July 25, 2016 :
Unfortunately, the FF_Format() routine does not (yet) support FAT12, only FAT16 and FAT32.
Two parameters indicate your preference:
xPreferFAT16: try to use FAT16, if not possible, try FAT32
xSmallClusters: try small clusters first, if not possibly, try larger clusters.
Larger clusters are more efficient in terms of speed, small clusters have less waste of space.
Microsoft states that:
if( CountofClusters < 4085 )
/* Volume is FAT12 */
else if( CountofClusters < 65525 )
/* Volume is FAT16 */
/* Volume is FAT32 */
+FAT is following Microsoft’s guidelines to get a maximum compatibility. However, you are not going to exchange your RAM disk with another system.
You could try the following in ff_format.c :
#ifdef ffconfigMIN_CLUSTERS_FAT16
#define MIN_CLUSTERS_FAT16 ffconfigMIN_CLUSTERS_FAT16
#else
#define MIN_CLUSTERS_FAT16 ( 4085 + 1 )
And define ffconfigMIN_CLUSTERS_FAT16 in your FreeRTOSFATConfig.h with a smaller value of e.g. :
#define ffconfigMIN_CLUSTERS_FAT16 1800
htibosch
(Hein Tibosch)
July 25, 2016, 10:00pm
6
Just tested in the WIN32 demo project and it works as expected.
A 2MB RAM-disk will get 4023 clusters, a 1MB disk gets1991 clusters. In these cases, each cluster will contain a single sector of 512 bytes.
