I’m using FreeRTOS Kernel 10.4.3 and the 2.5.0 version of the FreeRTOS specific UART drivers for the NXP MK24FN1M0VLQ12 MCU. When I try to use the UART_RTOS send and receive calls provided by that driver the code hangs at the xEventGroupWaitBits call. Trying to debug into that function just sends the processor into a reset.
EDIT:
Here is the applicable source code - it is 99% generated code from NXP’s MCUxpresso, including the peripheral initialization to try and keep human error out of things for solving this problem - my production code is doing the same thing:
- Copyright 2016-2024 NXP
- All rights reserved.
- SPDX-License-Identifier: BSD-3-Clause
- @file MK24F12_Project.cpp
- @brief Application entry point.
#include <stdio.h>
#include “board.h”
#include “peripherals.h”
#include “pin_mux.h”
#include “clock_config.h”
#include “MK24F12.h”
#include “fsl_debug_console.h”
#include “fsl_gpio.h”
#include “FreeRTOS.h”
#include “task.h”
#include “fsl_uart.h”
#include
/* TODO: insert other include files here. */
/* TODO: insert other definitions and declarations here. */
#define GPIO_PORTA GPIOA //GPIO A port data output register 0x400FF000
#define GPIO_PWRON_PIN 27u //ublox power on pin, MK24 PTA27 GPIO out, schematic CELL_ON_OFF signal,
// signal HIGH to turn on power the ublox
#define GPIO_RESET_PIN 28u //ublox reset pin, MK24 PTA28 GPIO out, schematic CELL_SHUTDN signal,
// signal HIGH to reset the ublox
#define GPIO_VINT_PIN 29u //ublox V_INT (1.8 VDC) pin, MK24 PTA29 GPIO in, schematic CELL_PWR_STAT signal,
// goes LOW when the ublox internal voltage regulator turns ON
#define GPIO_PORTA_PORT PORTA //Port A multiplexing control 0x40049000
const gpio_pin_config_t gpio_outputLowConfig = { kGPIO_DigitalOutput, 0 };
const gpio_pin_config_t gpio_outputHighConfig = { kGPIO_DigitalOutput, 1 };
const gpio_pin_config_t gpio_inputConfig = { kGPIO_DigitalInput, 0 };
void SaraOn()
GPIO_PinInit(GPIO_PORTA, GPIO_RESET_PIN, &gpio_outputLowConfig); // Configure GPIO as output and set LOW
GPIO_PinInit(GPIO_PORTA, GPIO_PWRON_PIN, &gpio_outputLowConfig); // Configure GPIO as output and set LOW
//wait for 100 ms
const TickType_t xDelay = 100 / portTICK_PERIOD_MS;
vTaskDelay( xDelay );
GPIO_PinWrite(GPIO_PORTA, GPIO_RESET_PIN, 1U); // set the cellular module reset pin LOW (HIGH at the mcu)
GPIO_PinWrite(GPIO_PORTA, GPIO_RESET_PIN, 0U); // set the cellular module reset pin HIGH (LOW at the mcu)
const TickType_t yDelay = 300 / portTICK_PERIOD_MS;
GPIO_PinWrite(GPIO_PORTA, GPIO_PWRON_PIN, 1U); // set the cellular module power on pin LOW (HIGH at the mcu)
vTaskDelay( yDelay );
GPIO_PinWrite(GPIO_PORTA, GPIO_PWRON_PIN, 0U); // set the cellular module power on pin HIGH (LOW at the mcu)
// Send AT command to cellular module
std::string txData = "AT\r";
std::string rxData = "123456789012";
UART_WriteBlocking(UART0, (uint8_t*)txData.c_str(), txData.size());
// UART_WriteBlocking(UART4, (uint8_t*)txData.c_str(), txData.size());
// UART_ReadBlocking(UART4, (uint8_t*)rxData.c_str(), rxData.size());
UART_RTOS_Send(&UART4_rtos_handle, (uint8_t*)txData.c_str(), txData.size());
size_t received = 0;
UART_RTOS_Receive(&UART4_rtos_handle, (uint8_t*)rxData.c_str(), rxData.size(), &received);
txData = "Received data:\r\n";
UART_WriteBlocking(UART0, (uint8_t*)rxData.c_str(), rxData.size());
static TaskHandle_t TestHandle;
void Test_Thread(void const *argument)
SaraOn();
while (1);
int main(void) {/* Init board hardware. /
BOARD_InitBootPins();
BOARD_InitBootClocks();
BOARD_InitBootPeripherals();
#ifndef BOARD_INIT_DEBUG_CONSOLE_PERIPHERAL
/ Init FSL debug console. */
BOARD_InitDebugConsole();
#endifPRINTF(“Hello World\r\n”);
xTaskCreate((TaskFunction_t)Test_Thread, “TEST”, configMINIMAL_STACK_SIZE, NULL, configMAX_PRIORITIES - 3, &TestHandle);
vTaskStartScheduler();
/* Force the counter to be placed into memory. /
volatile static int i = 0 ;
/ Enter an infinite loop, just incrementing a counter. /
while(1) {
i++ ;
/ ‘Dummy’ NOP to allow source level single stepping of
tight while() loop */
__asm volatile (“nop”);
return 0 ;
