I believe the setting for ipconfigNETWORK_MTU on this page should be 586, not 576: https://www.freertos.org/FreeRTOS-Plus/FreeRTOS_Plus_TCP/TCP_IP_Configuration_Examples.html
Is so:
MSS = MTU - ( ipSIZE_OF_IPv4_HEADER + ipSIZE_OF_TCP_HEADER )
That is actually the largest MSS you can use, given the MTU. FreeRTOS+TCP or a peer may decide to use a smaller value for MSS.
I would recommend to use the definition of ipconfigTCP_MSS as it is, and if you want to save RAM, I would decrease ipconfigNETWORK_MTU.
DHCP is asking for a certain minimum, which depends on the number of options that are exchanged. I should check FreeRTOS_DHCP.c to see which value is better.
Thank you Hein, I think I have some studying to do.
Hi Richard,
I was referring to the value for MTU, not MSS. The value shown on the web page, 576, appears to be too small if DHCP is being used.
