jordied wrote on Sunday, May 25, 2014:
Hmmm, I still can’t get it to work. I tried your suggestion Hein.
So you can try and understand more, here is more of what’s going on
main.c
#include "netduinoplus2.h"
#include "debug_printf.h"
#include "nrf24l01plus.h"
#include "netconf.h"
#include "FreeRTOS.h"
#include "task.h"
#include "queue.h"
#include "semphr.h"
#include "tuioclient.h"
#include "usbd_cdc_vcp.h"
#include "FreeRTOS_CLI.h"
#include "tcpip.h"
#include "lwip/opt.h"
#include "lwip/api.h"
#include "lwip/sys.h"
#include "lwip/sockets.h"
#include <string.h>
#include <stdio.h>
#include <stdlib.h>
#include "hardware.h"
#include "utility.h"
#include "convolutional.h"
#include "hamming.h"
/* Private typedef -----------------------------------------------------------*/
/* Private define ------------------------------------------------------------*/
#define TCP_SOCKET_PORT 3000
#define UDP_SOCKET_PORT 3333
#define START_BASE_ADDRESS 0x12345678
#define DEBUG 1
#define EXPECT_NOTHING 0
#define EXPECT_PASSKEY 1
#define EXPECT_SENSOR 2
/* Task Priorities -----------------------------------------------------------*/
#define SERVOTASK_PRIORITY ( tskIDLE_PRIORITY + 1 )
#define UDPTASK_PRIORITY ( tskIDLE_PRIORITY + 1 )
#define mainCLI_PRIORITY ( tskIDLE_PRIORITY + 2 )
#define mainRADIO_PRIORITY ( tskIDLE_PRIORITY + 1 )
/* Task Stack Allocations -----------------------------------------------------*/
#define SERVOTASK_STACK_SIZE ( configMINIMAL_STACK_SIZE * 2)
#define UDPTASK_STACK_SIZE ( configMINIMAL_STACK_SIZE * 2 )
#define mainCLI_TASK_STACK_SIZE ( configMINIMAL_STACK_SIZE * 10 )
#define mainRADIO_TASK_STACK_SIZE ( configMINIMAL_STACK_SIZE * 4 )
/* Private macro -------------------------------------------------------------*/
/* Private variables ---------------------------------------------------------*/
xQueueHandle ServoQueue1; /* Queue used */
int radioExpecting = EXPECT_NOTHING;
extern uint8_t SequenceNumber;
extern uint8_t Passkey;
/* Private function prototypes -----------------------------------------------*/
static void Hardware_init();
// Servo Contol Tasks
void UDPTask(void * pvParameters);
void ServoTask(void * pvParameters);
void RadioReceiveTask(void * pvParameters);
// CLI functions and task
void CLI_Task(void);
static portBASE_TYPE prvEchoCommand(char *pcWriteBuffer, size_t xWriteBufferLen, const char *pcCommandString );
static portBASE_TYPE prvLaserCommand(char *pcWriteBuffer, size_t xWriteBufferLen, const char *pcCommandString );
static portBASE_TYPE prvStateCommand(char *pcWriteBuffer, size_t xWriteBufferLen, const char *pcCommandString );
static portBASE_TYPE prvConvCommand(char *pcWriteBuffer, size_t xWriteBufferLen, const char *pcCommandString );
static portBASE_TYPE prvDecodeCommand(char *pcWriteBuffer, size_t xWriteBufferLen, const char *pcCommandString );
static portBASE_TYPE prvGetPasskeyCommand(char *pcWriteBuffer, size_t xWriteBufferLen, const char *pcCommandString );
static portBASE_TYPE prvGetSensorCommand(char *pcWriteBuffer, size_t xWriteBufferLen, const char *pcCommandString );
static portBASE_TYPE prvRFChanSetCommand(char *pcWriteBuffer, size_t xWriteBufferLen, const char *pcCommandString );
static portBASE_TYPE prvGetTimeCommand(char *pcWriteBuffer, size_t xWriteBufferLen, const char *pcCommandString );
#ifdef DEBUG
static portBASE_TYPE prvDEBUGCommand(char *pcWriteBuffer, size_t xWriteBufferLen, const char *pcCommandString );
void vApplicationIdleHook( void ); /* The idle hook is just used to stream data to the USB port.*/
xCommandLineInput xGetTime= { /* Structure that defines the "getpasskey" command line command. */
"gettime",
"gettime: Get the system uptime\r\n",
prvGetTimeCommand,
0
int main(void) {
NP2_boardinit();
debug_printf("Hardware .\n\r");
Hardware_init();
debug_printf("LWIP tasks.\n\r");
/* Initilaize the LwIP stack */
LwIP_Init();
debug_printf("Create tasks.\n\r");
xTaskCreate( (void *) &ServoTask, (const signed char *) "Servo", SERVOTASK_STACK_SIZE, NULL, SERVOTASK_PRIORITY, NULL);
xTaskCreate( (void *) &UDPTask, (const signed char *) "UDP", UDPTASK_STACK_SIZE, NULL,UDPTASK_PRIORITY, NULL);
xTaskCreate( (void *) &CLI_Task, (const signed char *) "CLI", mainCLI_TASK_STACK_SIZE, NULL, mainCLI_PRIORITY, NULL );
xTaskCreate( (void *) &RadioReceiveTask, (const signed char *) "RADIO", mainRADIO_TASK_STACK_SIZE, NULL, mainRADIO_PRIORITY, NULL );
debug_printf("Start CLI\n\r");
// Register CLI Commands //
FreeRTOS_CLIRegisterCommand(&xGetTime);
debug_printf("Start scheduler.\n\r");
/* Start scheduler */
vTaskStartScheduler();
return 0;
static portBASE_TYPE prvGetTimeCommand(char *pcWriteBuffer, size_t xWriteBufferLen, const char *pcCommandString ) {
/* Get tasks */
signed char * buffer =(signed char *) pcWriteBuffer;
vTaskGetRunTimeStats(buffer);
/* print out tasks */
debug_printf("\n\r----------------------------------------------\n\r%s\n\r----------------------------------------------\n\r", buffer);
/* Return pdFALSE, as there are no more strings to return */
/* Only return pdTRUE, if more strings need to be printed */
xWriteBufferLen = sprintf((char *) pcWriteBuffer, "\n\r%s\n\r",buffer);
return pdFALSE;
unsigned getRunTimeCounterValue(void){
return ulHighFrequencyTimerTicks;
void configureTimerForRunTimeStats(void)
ulHighFrequencyTimerTicks = 0UL;
and FreeRTOSConfig.h
FreeRTOS V7.5.3 - Copyright (C) 2013 Real Time Engineers Ltd.
All rights reserved
VISIT http://www.FreeRTOS.org TO ENSURE YOU ARE USING THE LATEST VERSION.
* FreeRTOS provides completely free yet professionally developed, *
* robust, strictly quality controlled, supported, and cross *
* platform software that has become a de facto standard. *
* Help yourself get started quickly and support the FreeRTOS *
* project by purchasing a FreeRTOS tutorial book, reference *
* manual, or both from: http://www.FreeRTOS.org/Documentation *
* Thank you! *
This file is part of the FreeRTOS distribution.
FreeRTOS is free software; you can redistribute it and/or modify it under
the terms of the GNU General Public License (version 2) as published by the
Free Software Foundation >>!AND MODIFIED BY!<< the FreeRTOS exception.
>>! NOTE: The modification to the GPL is included to allow you to distribute
>>! a combined work that includes FreeRTOS without being obliged to provide
>>! the source code for proprietary components outside of the FreeRTOS
>>! kernel.
FreeRTOS is distributed in the hope that it will be useful, but WITHOUT ANY
WARRANTY; without even the implied warranty of MERCHANTABILITY or FITNESS
FOR A PARTICULAR PURPOSE. Full license text is available from the following
link: http://www.freertos.org/a00114.html
1 tab == 4 spaces!
* Having a problem? Start by reading the FAQ "My application does *
* not run, what could be wrong?" *
* http://www.FreeRTOS.org/FAQHelp.html *
http://www.FreeRTOS.org - Documentation, books, training, latest versions,
license and Real Time Engineers Ltd. contact details.
http://www.FreeRTOS.org/plus - A selection of FreeRTOS ecosystem products,
including FreeRTOS+Trace - an indispensable productivity tool, a DOS
compatible FAT file system, and our tiny thread aware UDP/IP stack.
http://www.OpenRTOS.com - Real Time Engineers ltd license FreeRTOS to High
Integrity Systems to sell under the OpenRTOS brand. Low cost OpenRTOS
licenses offer ticketed support, indemnification and middleware.
http://www.SafeRTOS.com - High Integrity Systems also provide a safety
engineered and independently SIL3 certified version for use in safety and
mission critical applications that require provable dependability.
1 tab == 4 spaces!
#ifndef FREERTOS_CONFIG_H
#define FREERTOS_CONFIG_H
* Application specific definitions.
* These definitions should be adjusted for your particular hardware and
* application requirements.
* THESE PARAMETERS ARE DESCRIBED WITHIN THE 'CONFIGURATION' SECTION OF THE
* FreeRTOS API DOCUMENTATION AVAILABLE ON THE FreeRTOS.org WEB SITE.
* See http://www.freertos.org/a00110.html.
#define configCOMMAND_INT_MAX_OUTPUT_SIZE 1024 //1024
#define configUSE_IDLE_HOOK 0
#define configUSE_TICK_HOOK 0
#define configCPU_CLOCK_HZ ( ( unsigned long ) 25000000 )
#define configTICK_RATE_HZ ( ( portTickType ) 1000 )
#define configMAX_PRIORITIES ( ( unsigned portBASE_TYPE ) 5 )
#define configMINIMAL_STACK_SIZE ( ( unsigned short ) 120 )
#define configTOTAL_HEAP_SIZE ( ( size_t ) ( 18 * 1024 ) )
#define configMAX_TASK_NAME_LEN ( 16 )
// I modified
#define configUSE_STATS_FORMATTING_FUNCTIONS 1
/* ulHighFrequencyTimerTicks is already being incremented at 20KHz. Just set
its value back to 0. */
volatile unsigned long ulHighFrequencyTimerTicks;
extern unsigned getRunTimeCounterValue(void);
extern void configureTimerForRunTimeStats(void);
#define portCONFIGURE_TIMER_FOR_RUN_TIME_STATS configureTimerForRunTimeStats
#define portGET_RUN_TIME_COUNTER_VALUE getRunTimeCounterValue
/* Co-routine definitions. */
#define configMAX_CO_ROUTINE_PRIORITIES ( 2 )
#define configUSE_MUTEXES 1
#define configUSE_COUNTING_SEMAPHORES 1
#define configUSE_ALTERNATIVE_API 0
#define configUSE_RECURSIVE_MUTEXES 1
#define configQUEUE_REGISTRY_SIZE 0
#define configGENERATE_RUN_TIME_STATS 1
#define INCLUDE_vTaskPrioritySet 1
#define INCLUDE_uxTaskPriorityGet 1
#define INCLUDE_vTaskDelete 1
#define INCLUDE_vTaskCleanUpResources 0
#define INCLUDE_vTaskSuspend 0 //1
#define INCLUDE_vTaskDelayUntil 1
#define INCLUDE_vTaskDelay 1
/* Cortex-M specific definitions. */
#ifdef __NVIC_PRIO_BITS
/* __BVIC_PRIO_BITS will be specified when CMSIS is being used. */
#define configPRIO_BITS __NVIC_PRIO_BITS
#else
#define configPRIO_BITS 4 /* 15 priority levels */
function. */
#define configLIBRARY_LOWEST_INTERRUPT_PRIORITY 0xf
routine that makes calls to interrupt safe FreeRTOS API functions. DO NOT CALL
#define configLIBRARY_MAX_SYSCALL_INTERRUPT_PRIORITY 5
/* Interrupt priorities used by the kernel port layer itself. These are generic
#define configKERNEL_INTERRUPT_PRIORITY ( configLIBRARY_LOWEST_INTERRUPT_PRIORITY << (8 - configPRIO_BITS) )
#define configMAX_SYSCALL_INTERRUPT_PRIORITY ( configLIBRARY_MAX_SYSCALL_INTERRUPT_PRIORITY << (8 - configPRIO_BITS) )
/* Normal assert() semantics without relying on the provision of an assert.h
header file. */
#define configASSERT( x ) if( ( x ) == 0 ) { taskDISABLE_INTERRUPTS(); for( ;; ); }
/* Definitions that map the FreeRTOS port interrupt handlers to their CMSIS
standard names. */
