Trying to port to xmega256A3...
travisgriggs wrote on Monday, November 26, 2012:
We have some code where I work at that runs on an xmega256A3. I think it’s overtly complex with all of its state machines, and would like to try using FreeRTOS with it. I’m new to this. I’ve read through a bunch of the docs. I downloaded the latest (I’m excited about the tickless support, because we frequently sleep to save power). And I think I’m correct in noticing that this processor is not an official supported port. I’m developing on an OSX box with CrossPack’s AVR toolchain and avrdude.
So I cloned Demo/AVR_ATMega323_WinAVR, that seemed like it would be the most similar to the xmega256a3 and my platform. I made minor adjustments to the makefile (adjusted the DIRAVR and MCU variables).
When I try to ‘make’ from there, I get the following error:
ParTest/ParTest.c:102:2: error: ‘DDRB’ undeclared (first use in this function)
What confuses me though, is where DDRB would normally come from? A ‘grep -R “DDRB” *’ at the root FreeRTOS directory level, doesn’t turn up anything that gives me any hints about what to do to resolve it for my target…
Any help/hints with this specific issue, as well as any general guidance about what else I’m going to need to do to make this work, are much appreciated. I would love to hear that there’s already been a port to the xmega256a3…
edwards3 wrote on Monday, November 26, 2012:
I just looked in partest.c (the file that generates the error) for the AVR GCC port and it contains the line:
DDRB = partstALL_BITS_OUTPUT;
FreeRTOSConfig.h includes <avr/io.h> so the definition must come from there.
I guess that is a data direction register for port B? I suspect the name used by the compiler has changed since the demo was written.
You will find other AVR ports in the Interactive site http://interactive.freertos.org/forums/103473-atmel. Also check out the forums at
http://www.avrfreaks.net
where there are some FreeRTOS users.
