Every time I select the &RecorderData in the Memory Browser and I export the data (with the sizeof( RecorderDataType )) i can’t open it in Tracealyzer for FreeRTOS.
The error is:
"Failed to load trace: Cannot load Counter Name data because an invalid
index " was read from the registry. "
That is a very old demo and the trace files have changed a number of
types since it was created.
Does that example build the code from the
/FreeRTOS-Plus/Source/FreeRTOS-Plus-Trace directory? Or does it have a
local copy of the trace functions?
It might be better to take a trace config file from one of the newer
demos. You could use the one from the maintained Win32 demo (from the
FreeRTOS/Demo/Win32-MingW directory) but you would have the change the
port from Win32 to Cortex-M.
