1. In documentation nothing about parameter portBASE_TYPE *pxHigherPriorityTaskWoken may be NULL
2. the same situation in documentation xQueueSendFromISR() about portBASE_TYPE *pxHigherPriorityTaskWoken
I do not remember why I use **NULL ** in xQueueSendFromISR(queue,item, NULL) (was in documentation in past or simply I have brose source code what I should not?) if I do not want feature of “task woken”.
In similar method from timers when I browse source code, NULL is not supported! and it is ok, since it is not in documentation.
Hewer why in xQueueSendFromISR() NULL is supported since is also not in documentation.
PS.
I wopuld prefer support NULL in both, since I do not use this feature and I would like to keep it simply.
Sorry - you say there is a bug, but I can’t understand from your post what the bug is.
Currently the timer API that can be used from an ISR cannot have its last parameter set to NULL, and I don’t think anything in the documentation says it can. The queue/semaphore implementation can set the parameter to NULL, but this is also not documented so I don’t think people using the API documentation will be trying to do that yet.
Are you reporting a bug in the timer implementation, or are you saying you can’t use the interrupt safe timer API with pxHigherPriorityTaskWoken parameter set to NULL and you wish to do so (in which case it would be a feature request rather than bug report).
+ The last parameter in ISR safe FreeRTOS functions
(xHigherPriorityTaskWoken) is now optional and can be set to NULL if it
is not required.
period.
than is a bug because:
1. this point do not refer to any specific module like, queue, timers or semaphores
however is a history.txt a official documentation? I do not know… I guess not. Please do not feel offend.
just my few thoughts of possibly inconsistent/bug depend on how to treat.
Ok - now I understand. I have updated the History.txt file, which now reads
The last parameter in ISR safe FreeRTOS queue and semaphore functions
is not required.
