static CellularATError_t parseT3324TimerValue( char * pToken,
uint32_t * pTimerValueSeconds )
int32_t tempValue = 0;
uint32_t tokenValue = 0;
uint32_t timerUnitIndex = 0;
uint32_t timerValue = 0;
CellularATError_t atCoreStatus = Cellular_ATStrtoi( pToken, 2, &tempValue );
if( atCoreStatus == CELLULAR_AT_SUCCESS )
if( tempValue < 0 )
LogError( ( "Error in processing Periodic Processing Active time value. Token %s", pToken ) );
atCoreStatus = CELLULAR_AT_ERROR;
tokenValue = ( uint32_t ) tempValue;
timerUnitIndex = T3324_TIMER_UNIT( tokenValue );
timerValue = T3324_TIMER_VALUE( tokenValue );
/* Parse the time unit. */
switch( timerUnitIndex )
case T3324_TIMER_UNIT_2SECONDS:
*pTimerValueSeconds = timerValue * 2u;
break;
case T3324_TIMER_UNIT_1MINUTE:
*pTimerValueSeconds = timerValue * 60U;
break;
case T3324_TIMER_UNIT_DECIHOURS:
*pTimerValueSeconds = timerValue * ( 15U * 60U );
break;
case T3324_TIMER_UNIT_DEACTIVATED:
*pTimerValueSeconds = T3324_TIMER_DEACTIVATED;
break;
default:
LogError( ( "Invalid T3324 timer unit index" ) );
break;
return atCoreStatus;
when case T3324_TIMER_UNIT_DECIHOURS, why timervalue = x * ( 15U * 60U ) ?
