I am working on a project which is using a QSPI peripheral to talk to a QSPI Flash device. I am using the XQspiPs driver provided by Xilinx. However, since this driver is not thread-safe, I have created my own wrapper around it using a mutex. I have created a higher level driver that uses my QSPI driver to talk to the QSPI flash memory. A part of any write functions in that driver is a loop that continuously checks if the write was successful by reading the flash status. I want to make sure that if the write is not successful within a certain amount of time, the while loop will timeout and break. I have done it in this way and want to know if this is the best way to do it:
/* Initialize timeout. This records the time at which this function was entered. */
vTaskSetTimeOutState( &timeout );
while (1)
* Poll the status register of the FLASH to determine when
* Quad Mode is enabled and the device is ready, by sending
* a read status command and receiving the status byte
status = qspi_read(_p_qspi_master_device, read_status_command, flash_status, sizeof(read_status_command));
if (status != CR02_SUCCESS)
CR02_DEBUG_PRINT(CR02_DEBUG_ERROR, "qspi_flash_quad_enable : Unable to read status register from QSPI flash.\r\n");
return status;
* If 6th bit is set & 0th bit is reset, then Quad is Enabled
* and device is ready.
if ((flash_status[0] == 0x40) && (flash_status[1] == 0x40))
break;
if(xTaskCheckForTimeOut(&timeout, &ticks_to_wait) != pdFALSE)
/* Timeout occurred - flash took too long to indicate quad spi enable successful. Exit the loop. */
CR02_DEBUG_PRINT(CR02_DEBUG_ERROR, "qspi_flash_quad_enable : Quad enable timeout.\r\n");
return CR02_FAILURE;
If this is not the best way to implement a timeout in FreeRTOS, is there a best-known-method?
Thank you for your time,
-Sid
