Thread is not running
I am using STM32F429ZIT6 on a custom PCB
  • FreeRTOS API : CMSISv1
  • LWIP v2.1.2
  • Ethernet PHY : LAN8742A
I am trying to handle cases when link is up or down
if I call
MX_LWIP_Init();
before
  osThreadDef(defaultTask, StartDefaultTask, osPriorityNormal, 0, 2048); //was 2048
  defaultTaskHandle = osThreadCreate(osThread(defaultTask), NULL);
then StartDefaultTask thread doesnt run but the Ethernet link handler thread runs.
Any Idea what is preventing those two threads to run ?
#define configCPU_CLOCK_HZ                       ( SystemCoreClock )
#define configTICK_RATE_HZ                       ((TickType_t)1000)
#define configMAX_PRIORITIES                     ( 7 )
#define configMINIMAL_STACK_SIZE                 ((uint16_t)1024)
#define configTOTAL_HEAP_SIZE                    ((size_t)15360)
#define configMAX_TASK_NAME_LEN                  ( 16 )
int main(void)
  /* USER CODE BEGIN 1 */
  /* USER CODE END 1 */
  /* MCU Configuration--------------------------------------------------------*/
  /* Reset of all peripherals, Initializes the Flash interface and the Systick. */
  HAL_Init();
  /* USER CODE BEGIN Init */
  /* USER CODE END Init */
  /* Configure the system clock */
  SystemClock_Config();
  /* USER CODE BEGIN SysInit */
  /* USER CODE END SysInit */
  /* Initialize all configured peripherals */
  MX_GPIO_Init();
  MX_TIM1_Init();
  MX_TIM2_Init();
  MX_USART3_UART_Init();
  /* USER CODE BEGIN 2 */
  HAL_TIM_Encoder_Start(&htim2, TIM_CHANNEL_ALL);
  HAL_TIM_OC_Start_IT(&htim1, TIM_CHANNEL_1);
  /* USER CODE END 2 */
  /* USER CODE BEGIN RTOS_MUTEX */
  /* add mutexes, ... */
  /* USER CODE END RTOS_MUTEX */
  /* USER CODE BEGIN RTOS_SEMAPHORES */
  /* add semaphores, ... */
  /* USER CODE END RTOS_SEMAPHORES */
  /* USER CODE BEGIN RTOS_TIMERS */
  /* start timers, add new ones, ... */
  /* USER CODE END RTOS_TIMERS */
  /* USER CODE BEGIN RTOS_QUEUES */
  /* add queues, ... */
  /* USER CODE END RTOS_QUEUES */
  /* Create the thread(s) */
  /* definition and creation of defaultTask */
  /* USER CODE BEGIN RTOS_THREADS */
  /* add threads, ... */
  /* USER CODE END RTOS_THREADS */
  /* Start scheduler */
  osKernelStart();
void MX_LWIP_Init(void)
  /* IP addresses initialization */
  IP_ADDRESS[0] = 192;
  IP_ADDRESS[1] = 168;
  IP_ADDRESS[2] = 10;
  IP_ADDRESS[3] = 200;
  NETMASK_ADDRESS[0] = 255;
  NETMASK_ADDRESS[1] = 255;
  NETMASK_ADDRESS[2] = 255;
  NETMASK_ADDRESS[3] = 0;
  GATEWAY_ADDRESS[0] = 192;
  GATEWAY_ADDRESS[1] = 168;
  GATEWAY_ADDRESS[2] = 10;
  GATEWAY_ADDRESS[3] = 1;
/* USER CODE BEGIN IP_ADDRESSES */
/* USER CODE END IP_ADDRESSES */
  /* Initilialize the LwIP stack with RTOS */
  tcpip_init( NULL, NULL );
  /* IP addresses initialization without DHCP (IPv4) */
  IP4_ADDR(&ipaddr, IP_ADDRESS[0], IP_ADDRESS[1], IP_ADDRESS[2], IP_ADDRESS[3]);
  IP4_ADDR(&netmask, NETMASK_ADDRESS[0], NETMASK_ADDRESS[1] , NETMASK_ADDRESS[2], NETMASK_ADDRESS[3]);
  IP4_ADDR(&gw, GATEWAY_ADDRESS[0], GATEWAY_ADDRESS[1], GATEWAY_ADDRESS[2], GATEWAY_ADDRESS[3]);
  /* add the network interface (IPv4/IPv6) with RTOS */
  netif_add(&gnetif, &ipaddr, &netmask, &gw, NULL, &ethernetif_init, &tcpip_input);
  /* Registers the default network interface */
  netif_set_default(&gnetif);
  if (netif_is_link_up(&gnetif))
    /* When the netif is fully configured this function must be called */
    netif_set_up(&gnetif);
    /* When the netif link is down this function must be called */
    netif_set_down(&gnetif);
  /* Set the link callback function, this function is called on change of link status*/
  netif_set_link_callback(&gnetif, ethernetif_update_config);
  /* create a binary semaphore used for informing ethernetif of frame reception */
  osSemaphoreDef(Netif_SEM);
  Netif_LinkSemaphore = osSemaphoreCreate(osSemaphore(Netif_SEM) , 1 );
  link_arg.netif = &gnetif;
  link_arg.semaphore = Netif_LinkSemaphore;
  /* Create the Ethernet link handler thread */
/* USER CODE BEGIN OS_THREAD_DEF_CREATE_CMSIS_RTOS_V1 */
  osThreadDef(LinkThr, ethernetif_set_link, osPriorityBelowNormal, 0, configMINIMAL_STACK_SIZE* 2);
  osThreadCreate (osThread(LinkThr), &link_arg);
/* USER CODE END OS_THREAD_DEF_CREATE_CMSIS_RTOS_V1 */
/* USER CODE BEGIN 3 */
/* USER CODE END 3 */
The heap size seems a bit small with regard of running the network stack and already allocating 2 * 2048 byte for the task stacks. Maybe you’re running out of heap after the network stack has been started because it might allocate memory internally.
Do you check the return value of osThreadCreate i.e. checking defaultTaskHandle being valid or NULL ?
I do not check return value of osThreadCreate I will do that.
I just doubled heap size to 30720 and the thread started running!
Thank you sir
