I use STM32CUBEMX to create code,and when the code is running,I find a problem.My code is stuck at prvCheckTasksWaitingTermination.
Simple Description with my system:
1,freertos use systick, and HAL use TIM7
2,two simple task,one is flashing led,other is RFID test function,as below
void StartDefaultTask(void *argument)
/* USER CODE BEGIN StartDefaultTask */
/* Infinite loop */
for(;;)
HAL_GPIO_TogglePin(SYS_LED_GPIO_Port,SYS_LED_Pin);
osDelay(500);
/* USER CODE END StartDefaultTask */
void StartTask02(void *argument)
/* USER CODE BEGIN StartTask02 */
/* Infinite loop */
for(;;)
inventoryGen2_fast();
osDelay(500);
/* USER CODE END StartTask02 */
simple test result:
1,when run code without modifing nothing,the first time,the code execute over inventoryGen2_fast(),and try run into osDelay(500),the code may stack at function of “prvCheckTasksWaitingTermination”,and never resume;
2,when i annotate the code “inventoryGen2_fast()”,the system can run ok;
3,when i annotate the code “HAL_SPI_TransmitReceive” which in the function of inventoryGen2_fast(),the system can run ok;
so i get a primary result that the “HAL_SPI_TransmitReceive” may cause some problem,when goon running “osDelay”,but i can’t solve the problem, pls give some help thanks.
some code as below:
osStatus_t osDelay (uint32_t ticks) {
osStatus_t stat;
if (IS_IRQ()) {
stat = osErrorISR;
else {
stat = osOK;
if (ticks != 0U) {
vTaskDelay(ticks);
return (stat);
HAL_StatusTypeDef HAL_SPI_TransmitReceive(SPI_HandleTypeDef *hspi, uint8_t *pTxData, uint8_t *pRxData, uint16_t Size,
uint32_t Timeout)
uint16_t initial_TxXferCount;
uint32_t tmp_mode;
HAL_SPI_StateTypeDef tmp_state;
uint32_t tickstart;
/* Variable used to alternate Rx and Tx during transfer */
uint32_t txallowed = 1U;
HAL_StatusTypeDef errorcode = HAL_OK;
/* Check Direction parameter */
assert_param(IS_SPI_DIRECTION_2LINES(hspi->Init.Direction));
/* Process Locked */
__HAL_LOCK(hspi);
/* Init tickstart for timeout management*/
tickstart = HAL_GetTick();
/* Init temporary variables */
tmp_state = hspi->State;
tmp_mode = hspi->Init.Mode;
initial_TxXferCount = Size;
if (!((tmp_state == HAL_SPI_STATE_READY) || \
((tmp_mode == SPI_MODE_MASTER) && (hspi->Init.Direction == SPI_DIRECTION_2LINES) && (tmp_state == HAL_SPI_STATE_BUSY_RX))))
errorcode = HAL_BUSY;
goto error;
if ((pTxData == NULL) || (pRxData == NULL) || (Size == 0U))
errorcode = HAL_ERROR;
goto error;
/* Don't overwrite in case of HAL_SPI_STATE_BUSY_RX */
if (hspi->State != HAL_SPI_STATE_BUSY_RX)
hspi->State = HAL_SPI_STATE_BUSY_TX_RX;
/* Set the transaction information */
hspi->ErrorCode = HAL_SPI_ERROR_NONE;
hspi->pRxBuffPtr = (uint8_t *)pRxData;
hspi->RxXferCount = Size;
hspi->RxXferSize = Size;
hspi->pTxBuffPtr = (uint8_t *)pTxData;
hspi->TxXferCount = Size;
hspi->TxXferSize = Size;
/*Init field not used in handle to zero */
hspi->RxISR = NULL;
hspi->TxISR = NULL;
#if (USE_SPI_CRC != 0U)
/* Reset CRC Calculation */
if (hspi->Init.CRCCalculation == SPI_CRCCALCULATION_ENABLE)
SPI_RESET_CRC(hspi);
#endif /* USE_SPI_CRC */
/* Check if the SPI is already enabled */
if ((hspi->Instance->CR1 & SPI_CR1_SPE) != SPI_CR1_SPE)
/* Enable SPI peripheral */
__HAL_SPI_ENABLE(hspi);
/* Transmit and Receive data in 16 Bit mode */
if (hspi->Init.DataSize == SPI_DATASIZE_16BIT)
if ((hspi->Init.Mode == SPI_MODE_SLAVE) || (initial_TxXferCount == 0x01U))
hspi->Instance->DR = *((uint16_t *)hspi->pTxBuffPtr);
hspi->pTxBuffPtr += sizeof(uint16_t);
hspi->TxXferCount--;
while ((hspi->TxXferCount > 0U) || (hspi->RxXferCount > 0U))
/* Check TXE flag */
if ((__HAL_SPI_GET_FLAG(hspi, SPI_FLAG_TXE)) && (hspi->TxXferCount > 0U) && (txallowed == 1U))
/* Next Data is a reception (Rx). Tx not allowed */
txallowed = 0U;
/* Enable CRC Transmission */
if ((hspi->TxXferCount == 0U) && (hspi->Init.CRCCalculation == SPI_CRCCALCULATION_ENABLE))
SET_BIT(hspi->Instance->CR1, SPI_CR1_CRCNEXT);
/* Check RXNE flag */
if ((__HAL_SPI_GET_FLAG(hspi, SPI_FLAG_RXNE)) && (hspi->RxXferCount > 0U))
*((uint16_t *)hspi->pRxBuffPtr) = (uint16_t)hspi->Instance->DR;
hspi->pRxBuffPtr += sizeof(uint16_t);
hspi->RxXferCount--;
/* Next Data is a Transmission (Tx). Tx is allowed */
txallowed = 1U;
if (((HAL_GetTick() - tickstart) >= Timeout) && (Timeout != HAL_MAX_DELAY))
errorcode = HAL_TIMEOUT;
goto error;
/* Transmit and Receive data in 8 Bit mode */
*((__IO uint8_t *)&hspi->Instance->DR) = (*hspi->pTxBuffPtr);
hspi->pTxBuffPtr += sizeof(uint8_t);
*(__IO uint8_t *)&hspi->Instance->DR = (*hspi->pTxBuffPtr);
hspi->pTxBuffPtr++;
txallowed = 0U;
/* Wait until RXNE flag is reset */
(*(uint8_t *)hspi->pRxBuffPtr) = hspi->Instance->DR;
hspi->pRxBuffPtr++;
txallowed = 1U;
if ((((HAL_GetTick() - tickstart) >= Timeout) && ((Timeout != HAL_MAX_DELAY))) || (Timeout == 0U))
goto error;
/* Read CRC from DR to close CRC calculation process */
/* Wait until TXE flag */
if (SPI_WaitFlagStateUntilTimeout(hspi, SPI_FLAG_RXNE, SET, Timeout, tickstart) != HAL_OK)
/* Error on the CRC reception */
SET_BIT(hspi->ErrorCode, HAL_SPI_ERROR_CRC);
goto error;
/* Read CRC */
READ_REG(hspi->Instance->DR);
/* Check if CRC error occurred */
if (__HAL_SPI_GET_FLAG(hspi, SPI_FLAG_CRCERR))
/* Clear CRC Flag */
__HAL_SPI_CLEAR_CRCERRFLAG(hspi);
/* Check the end of the transaction */
if (SPI_EndRxTxTransaction(hspi, Timeout, tickstart) != HAL_OK)
hspi->ErrorCode = HAL_SPI_ERROR_FLAG;
goto error;
/* Clear overrun flag in 2 Lines communication mode because received is not read */
if (hspi->Init.Direction == SPI_DIRECTION_2LINES)
__HAL_SPI_CLEAR_OVRFLAG(hspi);
error :
hspi->State = HAL_SPI_STATE_READY;
__HAL_UNLOCK(hspi);
return errorcode;
