Am I missing it somewhere, or could it be considered to add the TCP version to a define somewhere? Something like
#define FREERTOS_TCP_VERSION “2.2.0”
Hello Erik!
As far as I know, there is no such #define in TCP source. But, yes it is a good idea to add this somewhere.
I think FreeRTOS_IP.h might be a good place to add this value in (FreeRTOSIPConfigDefaults.h should be reserved for configuration).
Would you like to create a PR for the same change in the FreeRTOS+TCP repository?
Regards,
Aniruddha
Agreed!
But what I possibly prefer is a numeric value that reflects the current version, like e.g. MAJOR, MINOR, SUB?
I’d prefer to use the same scheme as FreeRTOS core (in task.h).
I support this, it doesn’t matter to me, I’d just like some quick way to view the IP stack version from the application.
Just for reference: https://github.com/FreeRTOS/FreeRTOS-Kernel/blob/main/include/task.h#L47
Yes, that is perfect:
#define tskKERNEL_VERSION_NUMBER "V10.4.3"
#define tskKERNEL_VERSION_MAJOR 10
#define tskKERNEL_VERSION_MINOR 4
#define tskKERNEL_VERSION_BUILD 3
So you can easily test the version in the code.
Yes, can we name it as below?
ipFR_TCP_VERSION_NUMBER
ipFR_TCP_VERSION_MAJOR
ipFR_TCP_VERSION_MINOR
ipFR_TCP_VERSION_BUILD
And I am thinking of putting this in FreeRTOS_IP.c.
@friesen, would you be creating a PR (we’ll help you with the PR as well, no need to worry
) or I can do it for you if you’d prefer that.
I think it would work smoother for AWS to do this, as their present build may be more advanced than the present.
I have created a PR here: Tcp version macros by AniruddhaKanhere · Pull Request #255 · FreeRTOS/FreeRTOS-Plus-TCP (github.com)
@friesen, I was not sure of your github account ID thus, just mentioned you by name. I can update it with your github ID if you’d like.
github user friesendrywall
I updated my PR description!
EDIT: @friesen, the PR is merged.
Thank you for the suggestion!
