I am currently trying to implement the TCP server example from the labs demo onto my stm32f429_eval board.
So far I am able to compile the project with armcc (Keil).
I just encounter a problem, my prvConnectionListeningTask, respectively the FreeRTOS_accept never unblocks or should I say, it waits forever for the event. I tried the echotool to trigger the event, but the it returns “Can not connect to server”.
I have the same problem when I try to ping the device.
A hint where the unblocking event is generated would be highly appreciated. Or any other ideas that direct me in the right direction.
First question - as we don’t have one in the download ourselves - have
you implemented the pack_struct_start.h and pack_struct_end.h header
files for the Keil environment? This is very important and, if wrong,
could result in some protocols appearing to work (like the ICMP pings)
while others do not.
I maybe faced the same bug, it took me a long time to find…
The priority of the task running your TCP server must be lower than the
priority of the Ethernet task.
Am I right that I am missing the TCP server task, because I only want to use the echo server ? So I think I need to modify the mainECHO_SERVER_TASK_PRIORITY.
Even by using the defaults provided by the demo I am stuck in the prvConnectionListeningTask and the Echo server task is never created.
You are right, the “server work task” is not needed for the echo server
example, only examples that have state such as the FTP, HTTP and Telnet
servers.
So I can get it clear in my mind some questions:
Did you start with the code from this demo?
So it is clear you ported the demo to Keil. Did you make any other
changes? For example, take tasks out, or add new tasks, or change any
FreeRTOSConfig/FreeRTOSIPConfig.h settings?
If you built the original project with the [free] Atollic tools, did it
work then? Maybe it would be good to get that working before porting to
Keil.
unblocks
Is this function in
\FreeRTOS-Plus\Demo\Common\FreeRTOS_Plus_TCP_Demos\SimpleTCPEchoServer.c
no, you don’t need FreeRTOS_TCP_server.c for the Echo server in
SimpleTCPEchoServer.c.
prvConnectionListeningTask() (and better also
prvServerConnectionInstance()) must run at a lower priority than
ipconfigIP_TASK_PRIORITY.
I am not sure, I didn’t compare the sources but I used this demo:
FreeRTOS_Labs_160112\FreeRTOS-Plus\Demo\FreeRTOS_Plus_TCP_and_FAT_STM32F4xxx
from the FreeRTOSLabs.
I concensed the main to fit my needs ands also skip some initializion I am already doing in a startup task.
I zipped all the modification and used files in the attachment. I believe this compiles.
I will try the attolic approach and go from there. I suspect also some issues with my network configuration. But I can see a Broadcast of the device announcing its ip. Not the server ip obviously.
Edit:
In mz edited code I didn’t activate the ETH_IRQn so abviously I can’t get an event. Nonetheless, after enabling the interrupt the according IRQ handler calls the eth error callback because the ais flag is set. I think the NetworkInterface / DMA is not configured right. The example ist for a f409 and i am using an f429.
