I’m attempting to build a PPP driver for +TCP, I have it at the point of IP packets, the LCP and IPCP layers have completed.
I’m probably missing some concepts, feel free to enlighten me.
Anyway, ARP isn’t really applicable to PPP links, but ARP seems to have to initial resolve before anything can happen. Any suggestions how to bypass or make this work?
I think I’ll have to fiddle with ethernet headers to make this work too.
It looks like the best method is to write an ARP proxy, basically intercept and reply to ARP packets. In this case, I set mac addresses for a gateway and local IP, then set the gateway IP to 10.64.64.64, then intercept any gateway IP ARP requests and return the correct MAC. For this to work correctly #define ipconfigARP_STORES_REMOTE_ADDRESSES 1
otherwise it won’t store in the arp table, and the cache never hits.
As I understand you are trying to implement PPP over Ethernet (PPPoE).
PPP is a layer 2 protocol which essentially means that this need a routing table entry to be present.
In usual TCP/UDP communication the routing table entry is being populated using ARP.
In case of PPP, the source and destination will be fixed and a routing table entry can be created during the PPP socket init. The only limitation in this method is that the remote IP and MAC will have to be pre-known.
A usual practice followed by systems using PPoE together with other protocols is to use a 5 tuple based routing table (Local-IP/Local-Mac/Remote-IP/Remote-Mac/Protocol). This way a normal ARP can be used to populate the routing table , just that the protocol field will be PPPoE.
Yes I agree, ARP serves no purpose. But, a routing table entry is still needed for all routing needs. Hence, the first method that I had suggested can be used, where an entry can be added directly to the routing table.
Just to add , the procedure is called proxyARP where we manually create a routing table entry. However, this can be avoided altogether if we do not want to support routing or differentiate between different types of traffic.
